Axis Stops Processing GCode - Not Sure Why
- Highlander01
After it has stopped and hung up I hit the play button or pause button and it goes back to the beginning of the file.
Anyone see this before?
- acemi
Is there any link between a parallel port pin and halui.program.stop, motion.enable or something like that in your HAL file?
- digidocs
I don't think its a hardware issue because I'm running the the 9 axis simulator...
I'm currently re-running the job with the TkEMC GUI. So far so good there.
Hope we can sort this out...
-DC
- digidocs
-DC
- robh
- Thank you received: 24
which version of emc are you running and whats the pc specs might be useful for devs if there is a problem
i am running 2.3.4
and have run programs with 259358 lines of code (~6mb file) with some 3D surfacing with no problems
i have run bigger files (file size and code lines) also with no problems.
all in the axis GUI
my system specs are
2GB system ram
2.2GHz intel CPU
rob
- Highlander01
- Highlander01
- robh
if you still stumped then if you dont mind sharing the code file putting it on pastebin.ca or so and linking to it for others to test it out see where issue lied for you.
rob
- tedani
I'm having a similar issue where Axis just stops somewhere around 1K lines into a 20K+ line file.
-DC
Did you start your G-code by pressing "Execute next line" button? Check the following post to see if there is any similarity:
www.linuxcnc.org/component/option,com_ku...,0/lang,english/#438
- Highlander01
