Axis Stops Processing GCode - Not Sure Why
21 Feb 2010 07:04 #1972 by tedani
Highlander01 wrote:
Yes, out of habit I hit the next line and then after a few lines I then stop doing that and let it run.
To solve the problem without recompiling EMC2, you may add a "PAUSE" (may be a M0) at the beginning of your NC file. Start your code by pressing the "RUN" button, when EMC2 is paused by the M0 command, you can step through and resume the rest of your code without problem.
29 Apr 2010 03:27 #2743 by ZARF
I saw your problem with emc2 stopping at 1006 lines of code. Go into your Cad Cam software and setup your post to NOT output line numbers! Emc2 doesnt like line numbers.
CHEERS!
ZARF
Time to create page: 0.053 seconds
