External switch in MDI/MANUAL/AUTO mode
- aike
- Thank you received: 4
01 Apr 2012 05:25 #18894
by aike
External switch in MDI/MANUAL/AUTO mode was created by aike
Hi!
I use external panel to switch mode AUTO/MANUAL/MDI.
It works fine till I press the mouse and touch the screen.
If I was in MDI SCREEN mode (F3) not possible to switched in auto mode in external button.
If the program finished the manual mode becomes, but the external button is in AUTO mode!
Is it possible that screen switched from MDI mode to AUTO/MANUAL mode screen when I press external mode button switch?
- BigJohnT
- Thank you received: 1177
01 Apr 2012 11:05 #18895
by BigJohnT
Replied by BigJohnT on topic Re:External switch in MDI/MANUAL/AUTO mode
What do you use the switch for?
How is is connected up in HAL?
What GUI are you using?
- Rick G
- Thank you received: 155
01 Apr 2012 11:37 #18896
by Rick G
Replied by Rick G on topic Re:External switch in MDI/MANUAL/AUTO mode
It has been a while since I looked but it seems to me that if you used halui from say a usb joystick to switch from manual to mdi EMC2 will switch modes (as shown in the hal watch window) but the Axis GUI may not show the change.
Rick G
Rick G
- BigJohnT
01 Apr 2012 12:49 #18897
by BigJohnT
Rick,
I've not looked either but I think your correct that Axis will not respond to halui...
- aike
01 Apr 2012 14:11 #18898
by aike
Replied by aike on topic Re:External switch in MDI/MANUAL/AUTO mode
BigJohnT wrote:
The connection halui.mode.auto e t c
When I set "1" to halui.mode.auto or I set "1" to halui.mode.mdi, the screen not changes, while
ther are 2 screens (in menu), auto+manul and mdi.
If tell the true, the screens in AXIS GUI have to switches from one to other, if I change mode external buttons (not use F* keys or mouse).
I use AXIS.What do you use the switch for?
- dgarrett
- Thank you received: 325
01 Apr 2012 15:27 #18900
by dgarrett
Replied by dgarrett on topic Re:External switch in MDI/MANUAL/AUTO mode
Axis exposes some pins to hal:
halcmd: show pin axisui*
Component Pins:
Owner Type Dir Value Name
42 bit OUT FALSE axisui.jog.a
42 bit OUT FALSE axisui.jog.b
42 bit OUT FALSE axisui.jog.c
42 float OUT 0 axisui.jog.increment
42 bit OUT FALSE axisui.jog.u
42 bit OUT FALSE axisui.jog.v
42 bit OUT FALSE axisui.jog.w
42 bit OUT TRUE axisui.jog.x
42 bit OUT FALSE axisui.jog.y
42 bit OUT FALSE axisui.jog.z
42 bit IN FALSE axisui.notifications-clear
42 bit IN FALSE axisui.notifications-clear-error
42 bit IN FALSE axisui.notifications-clear-info
42 bit IN FALSE axisui.set-manual-mode
The pin axisui.set-manual-mode may be useful. You have to set it to 1 (then return to 0 to use again)
Component Pins:
- Rick G
01 Apr 2012 17:32 #18902
by Rick G
Rick G
I thought that would work to get axis into manual mode, but not to mdi mode.The pin axisui.set-manual-mode may be useful. You have to set it to 1 (then return to 0 to use again)
Rick G
