Display export with 2.5.x
- AkkiSan
05 Aug 2012 12:09 #22846
by AkkiSan
Display export with 2.5.x was created by AkkiSan
Usually, I don't use AXIS during milling, I'm fine with the TK interface.
But sometimes, I still use it on a remote system with the CNC machine turned off,
only to check some paths, etc...
In the past years, nothing else but a DISPLAY export was necessary, though
I usually used ssh -X...
This still works fine for the TK and MINI interface, but AXIS, as of LinuxCNC 2.5.x,
refuses to cooperate ("bad window").
Is this related to any hardware, Open-GL access?
How can I make this work again?
Thanks for any hint on this...
Akki
Akki
- ArcEye
- Thank you received: 758
05 Aug 2012 14:27 #22848
by ArcEye
Replied by ArcEye on topic Re:Display export with 2.5.x
Hi
I just tried ssh -X root@192.168.1.2 and was able to run Axis and Linuxcnc 2.5 on a remote machine
You will have to post the full error message, it is an X server error rather than Linuxcnc, seems most likely one of your machines has a problem with openGL.
Have you enabled -X and -Y in /etc/ssh/sshd.config so that it line reads X11Forwarding yes?
Assume must have if you tried other GUIs
Time to create page: 0.055 seconds
