Re:KeyChoice - Axis Key-Binding editor
14 years 2 months ago - 14 years 1 month ago #23743 by ArcEye
Replied by ArcEye on topic Re:KeyChoice - Axis Key-Binding editor
I have ported KeyChoice to Qt4 for those of you that already have this installed.
There are no dependencies in the .deb, if you have the Qt4 libraries installed it will work.**
(I did it as an exercise in discovering what Trolltech did to make Qt4 completely backwardly incompatible with Qt3 (without transition libraries).
Suppose I will have to start using Qt4 now, before support for Qt3 finishes in many distros. :( )
** Ensure that libQt3Support is installed
( Download now at next post )
Last edit: 14 years 1 month ago by ArcEye.
14 years 1 month ago #23858 by ArcEye
Hi
Updated versions of both the Qt3 and the Qt4 port of KeyChoice attached.
It now appends the new key bindings to the end of ~/.axisrc, if it already exists.
It still backs up .axisrc as well, found this was more convenient, even though I don't have anything much in it any more.
File Name: keychoice_v2.zip
File Size:43 KB
14 years 2 weeks ago #25267 by LAIR82
Replied by LAIR82 on topic Re:KeyChoice - Axis Key-Binding editor
Hello Arceye
I downloaded your editor, installed "sudo apt-get install libqt3-mt" in my "srt@Cinci:~/linuxcnc-dev$ " directory.
Do I do the "sudo dpkg -i keychoice_0.1-2_i386.deb" on that same line or do I need to go to
"srt@Cinci:~/linuxcnc-dev/src$" to apply it?
14 years 2 weeks ago - 14 years 2 weeks ago #25268 by ArcEye
Hi
It does not matter which directory you are in, so long as that is where the .deb is. dpkg will copy files to the correct absolute paths
If you wanted to keep it in a logical place, move the deb to /var/cache/apt/archives, as that is where the other packages you have downloaded since installation will be.
Last edit: 14 years 2 weeks ago by ArcEye.
14 years 2 weeks ago #25269 by LAIR82
I keep getting this error
srt@Cinci:~/linuxcnc-dev$ sudo dpkg -i keychoice_0.1-2_i386.debdpkg: error processing keychoice_0.1-2_i386.deb (--install):
cannot access archive: No such file or directory
Errors were encountered while processing:
I downloaded the zip folder, placed the download in my -dev folder, right clicked extract all, then did the terminal commands.
Any thoughts
14 years 2 weeks ago #25271 by ArcEye
If that is exactly what you are typing in, it is because the .deb is now called keychoice_1-2_i386.deb in this zip package
Do a ls in the directory, or even easier just enter sudo dpkg -i keychoice then press the Tab key and bash auto completion will fill in the rest
Time to create page: 0.404 seconds
