update to 4th axis
- noqui
27 Oct 2012 10:49 #25868
by noqui
update to 4th axis was created by noqui
Hi, i have a 3 axis CNC controller (sable 2015 from ebay) configurated in EMC2 like this:
PARALEL PORT
Pin 1 = Unused
Pin 2 = X Step Inverted=y
Pin 3 = X Directio Inverted=y
Pin 4 = Y Step Inverted=y
Pin 5 = Y Direction
Pin 6 = Z Step Inverted=y
Pin 7 = Z Direction
Pin 8 = Amplified Enable Inverted=y
Pin 9 = Amplified Enable Inverted=y
Pin 14 = Amplified Enable Inverted=y
Pins 10,11,12,13,15,16,17 Unused
Include custom HAL configuration =box checked
I want to install a 4th axis so i am planning to buy ebay item number:180993441260
Questions:
1) how do i have to configure the paralel port in EMC2 then?
2) What "amplified enable" does?
Thanks a lot
PARALEL PORT
Pin 1 = Unused
Pin 5 = Y Direction
Pin 7 = Z Direction
Questions:
Thanks a lot
- Thank you received: 4966
28 Oct 2012 00:59 #25897
Replied by andypugh on topic update to 4th axis
Hopefully the documentation with the drive will have that informationI want to install a 4th axis so i am planning to buy ebay item number:180993441260
It is used to enable the amplifiers. (Traditionally motor drives were called amplifiers. Technically they are)2) What "amplified enable" does?
- noqui
31 Oct 2012 07:07 #26107
by noqui
Replied by noqui on topic update to 4th axis
thank you andypugh
i configure it like this and it worked:
Pin 1 = Unused
Pin 2 = X Step
Pin 3 = X Directio
Pin 4 = Y Step
Pin 5 = Y Direction
Pin 6 = Z Step
Pin 7 = Z Direction
Pin 8 = A Step
Pin 9 = A Direction
Pin 17 = Amplified Enable
Pins 10,11,12,13,14,15,16,Unused
and it work. If i check Inverted boxes, it doesnt.
I sitl dont understand very well how it works.
Why if check the box it doesnt work and if i dont it does. What does and amplifier do? The signal has higher voltage? or what?.
Thanks a lot
Pin 1 = Unused
Pin 2 = X Step
Pin 3 = X Directio
Pin 4 = Y Step
Pin 5 = Y Direction
Pin 6 = Z Step
Pin 7 = Z Direction
Pin 8 = A Step
Pin 9 = A Direction
Thanks a lot
31 Oct 2012 07:17 #26108
Yes, the parallel port is 5V and 15mA. The motor runs at 24V and 3A. That means that the drive is an amplifier.tWhat does and amplifier do? The signal has higher voltage?
- noqui
31 Oct 2012 08:26 #26111
by noqui
Thanks a lot. Clear now
