Embed application in Axis
- REEEN
24 Mar 2013 20:59 #31799
by REEEN
Embed application in Axis was created by REEEN
Hello,
I really want to know wether it is possible to integrate an application into an Axis tab ?
I wanted to integrate a simple cad cam Programm into an Axis tab.
Thank you for your answers
Greets REEEN
Greets REEEN
- ArcEye
- Thank you received: 758
24 Mar 2013 21:47 #31802
by ArcEye
Replied by ArcEye on topic Embed application in Axis
Hi
See this
wiki.linuxcnc.org/cgi-bin/wiki.pl?Axis_Embed_Video
Yes you can, but only if the application supports embedding in the same way that mplayer, camview, rxvt etc do.
It is unlikely that any CAD program will do this however, they will be designed as a standalone GUI.
Have a look at the Axis code to see how embedded widgets are dealt with
See this
The following user(s) said Thank You: REEEN
- REEEN
25 Mar 2013 01:33 #31809
by REEEN
Replied by REEEN on topic Embed application in Axis
Okay thank you !
I think I`ll solve it on a different way
I installed the Cad Cam programme (gsimple) which is freeware within wine.
I open it with a user defined Mcode which is called with a Mdi command tied to a Pyvcp button.
I think the best way to use this Cad Cam programme in Axis is to place it over the Gremlin plot screen.
To do so I have to open the programme with a terminal command called with the user defined Mcode.
But the problem is I have to open it at a specific windowsize at a specific window position with a terminal command or a sript.
Has somedy got an idea how to do that ?
Thank you !
Thank you !
- ArcEye
25 Mar 2013 16:30 #31830
by ArcEye
Hi
This is one way
stackoverflow.com/questions/288512/resiz...-a-set-size-in-linux
Terminals have their own startup parameters quite often which allow you to specify size
This is another way
www.linuxcnc.org/index.php/english/forum/21-axis/320-faq
This is one way
This is another way
- REEEN
26 Mar 2013 08:36 #31888
by REEEN
Thank you I'll try this out!
I'll post a picture with the result and make a little video
Greets REEEN
Greets REEEN
Time to create page: 0.075 seconds
