Custom alarm message from input?
- DaOne
- Thank you received: 6
10 Jul 2013 11:41 #36479
by DaOne
Custom alarm message from input? was created by DaOne
Can someone tell me if there is a way to send a custom alarm message with e-stop for axis? Basically I want an input to trigger a estop (That part I got) but I also want it to tell the user why and be able to reset it if the problem is cleared. An example would be a servo overheat.
Thanks,
Wes
Thanks,
Wes
- ArcEye
- Thank you received: 758
10 Jul 2013 15:37 - 10 Jul 2013 15:38 #36490
by ArcEye
Replied by ArcEye on topic Custom alarm message from input?
Hi
There are any number of ways to do this, just depends what fits best with your set up.
Do you have an existing pyVCP panel?
You could incorporate a warning label which is disabled until triggered, or you could use my multi-label widget and trigger display of the warning using a bit pin.
Attaching to a halui.mdi-command-NN pin would enable you to run a M code script which could play music or verbal warning, display a notice etc
but this would have to be before the estop condition and whilst not in Auto mode, as it relies on MDI
A simple component could write an error to Axis or even pop up a dialog.
A component would probably be the cleanest implementation.
Regards reset, an Estop reset is always manual for safety reasons, but resetting the trigger should not be a problem, so long as it will continue to trigger if the problem recurs.
depends what you want to do
Last edit: 10 Jul 2013 15:38 by ArcEye.
- DaOne
10 Jul 2013 15:42 #36491
by DaOne
Replied by DaOne on topic Custom alarm message from input?
Thanks for the reply. Where would I find your multi-label widget?
- ArcEye
10 Jul 2013 17:40 #36493
by ArcEye
Hi
Its on this thread
www.linuxcnc.org/index.php/english/forum...-in-hal?limitstart=0
at
www.linuxcnc.org/media/kunena/attachment...9/pyvcp_widgets3.zip
I was envisaging setting Label0 to "" and Label1 to "Your Warning here", making sure that initval is set to 0 (first label)
Then activate
net trigger-signal pyvcp.multilabel.0.label1 <= error.from.whatever.source
to set the error message to display.
If you only have the one message, you could also do this by disabling a normal label and enabling it when error condition arises
Its on this thread
at
Then activate
- ArcEye
10 Jul 2013 20:23 #36496
by ArcEye
If that method does not suit, the next step up the ladder is the message component
linuxcnc.org/docs/2.5/html/man/man9/message.9.html
The following user(s) said Thank You: Stormholt
Time to create page: 0.097 seconds
