z auto touch off
02 Aug 2013 21:15 #37359
by charrier
z auto touch off was created by charrier
hi all
i use linuxcnc 2.5.2 with ubuntu 10.4
i try to use z auto touch off like the thread on the wiki classic ladder example but my result is bad plenty error and i don't understand
i put in the ini file the mdi command, in the .xml the button, in postgui file the connection, .
i try to install all by step by step and i try to lauch axis, at the begin all is good but when i change in custon.hal the load of z button touch off.clp
the problem come whit the errors that you find under that .
thanks for your reply
best regards
rv
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.24-16-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.4
LINUXCNC - 2.5.2
Machine configuration directory is '/home/charrier/linuxcnc/configs/ma-machine'
Machine configuration file is 'ma-machine.ini'
INIFILE=/home/charrier/linuxcnc/configs/ma-machine/ma-machine.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Killing task linuxcncsvr, PID=26126
INFO CLASSICLADDER---I/O modbus master closed!
INFO CLASSICLADDER---I/O modbus master (Ethernet) init ok !
ERROR CLASSICLADDER- Error intializing classicladder user module.
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
HAL: ERROR: duplicate component name 'classicladder'
custom.hal:3: program 'classicladder' failed, returned 255
26126
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
ULAPI: WARNING: module 'HAL_classicladder' failed to delete shmem 03
Kernel message information:
[372891.984942] I-pipe: Domain RTAI registered.
[372891.984957] RTAI[hal]: <3.6.1> mounted over IPIPE-NOTHREADS 2.0-04.
[372891.984960] RTAI[hal]: compiled with gcc version 4.2.4 (Ubuntu 4.2.4-1ubuntu3).
[372891.984966] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[372891.984969] PIPELINE layers:
[372891.984972] dcbbb000 9ac15d93 RTAI 200
[372891.984974] c0383180 0 Linux 100
[372892.000070] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[372892.000686] RTAI[sched]: loaded (IMMEDIATE, UP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[372892.000692] RTAI[sched]: hard timer type/freq = 8254-PIT/1193180(Hz); default timing: periodic; linear timed lists.
[372892.000696] RTAI[sched]: Linux timer freq = 250 (Hz), CPU freq = 1999814000 hz.
[372892.000700] RTAI[sched]: timer setup = 2010 ns, resched latency = 2689 ns.
[372892.103483] RTAI[math]: loaded.
[372892.285685] config string '0x378 out '
[372892.299594] creating ladder-state
[372893.527227] RTAI[math]: unloaded.
[372893.620099] SCHED releases registered named ALIEN RTGLBH
[372893.633708] RTAI[malloc]: unloaded.
[372893.732382] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[372893.734894] I-pipe: Domain RTAI unregistered.
[372893.734905] RTAI[hal]: unmounted.
best regards
rv
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.2
TASK=milltask
HALUI=halui
DISPLAY=axis
Cleanup done
26126
02 Aug 2013 22:43 #37366
by ArcEye
Replied by ArcEye on topic z auto touch off
Hi
zip seems corrupt, just contains a symlink
This is the error, I would suspect you are loading classicladder in your main hal file then doing it again in your custom.hal file
02 Aug 2013 23:09 #37370
by charrier
Replied by charrier on topic z auto touch off
hi arc eye thanks for your reponse
i put a # on custom hal file but i don't now where i must insert the name of .clp file for classic ladder can open it when axis open.
i can open it manualy but automaticly must be better
you have i am sure a solution
rv
rv
03 Aug 2013 16:12 - 03 Aug 2013 18:40 #37376
by ArcEye
Hi
The zip is still wrong
You have zipped a symlink called ma-machine which points to /home/charrier/linuxcnc/configs/ma-machine
instead of zipping the actual folder
In the meantime, this shows you how to load classicladder programs
EDIT
Or this even
www.linuxcnc.org/docs/devel/html/ladder/classic_ladder.html
EDIT
Or this even
Last edit: 03 Aug 2013 18:40 by ArcEye.
03 Aug 2013 16:59 #37377
by cncbasher
Replied by cncbasher on topic z auto touch off
in your main hal file :
# Chargement de Classicladder avec modbus maƮtre inclus (La GUI doit tourner avec Modbus)
loadusr classicladder --modmaster custom.clp
and also in your custom.hal
loadusr -w classicladder --nogui Touch_OFF_Button.clp
in your hal file you are loading 2 classic ladder programs
one in your main hal file and the other in your custom,hal
05 Aug 2013 20:12 - 05 Aug 2013 23:15 #37412
by charrier
Hi thanks
good target it's the reponse
now a new things i suppose make an error somwhere with the classic ladder example in the wiki : wiki.linuxcnc.org/cgi-bin/wiki.pl?ClassicLadderExamples
Single button probe/touchoff z auto touch off on button because nothing move
my mdi command are good i see in classiq ladder the mdi mode change, button z touch off too
, but ----[/[
%B0 and %B1 not turn on or off
i must forgot somethings but i don't now where
the mdi command g38.2 z-3 f16 work well
thanks
rv
, but ----[/[
thanks
rv
Last edit: 05 Aug 2013 23:15 by charrier.
