Using linuxcnc
03 Sep 2013 00:22 - 03 Sep 2013 00:24 #38434 by dimigav
Using linuxcnc was created by dimigav
I just download ubuntu-10.04-linuxcnc3-i386.iso and I install it in a laptop for testing.
I try to run Latency Test and nothing happens.
I try to run LinuxCNC and gives me a LinuxCNC Errors Window with many lines and header:
LinuxCNC terminated with an error. When reporting problems, please include all the information below in your message.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.3
Machine configuration directory is '/home/dimigav/linuxcnc/configs/3040T'
Machine configuration file is '3040T.ini'
INIFILE=/home/dimigav/linuxcnc/configs/3040T/3040T.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Realtime system did not load
Killing task linuxcncsvr, PID=2913
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
2913
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
/usr/bin/linuxcnc: line 433: 2951 Segmentation fault $HALCMD stop
Unloading hal components
/usr/bin/linuxcnc: line 433: 2952 Segmentation fault $HALCMD unload all
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000d0000 - 00000000000d4000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007ff60000 (usable)
[ 0.000000] BIOS-e820: 000000007ff60000 - 000000007ff6a000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007ff6a000 - 000000007ff6b000 (reserved)
[ 0.000000] BIOS-e820: 000000007ff6b000 - 000000007ff70000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007ff70000 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb80000 - 00000000ffc00000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
[ 0.000000] DMI present.
[ 0.000000] last_pfn = 0x7ff60 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-D3FFF write-back
[ 0.000000] D4000-D7FFF write-protect
[ 0.000000] D8000-DFFFF uncachable
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000009f800 (usable)
[ 0.000000] modified: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000d0000 - 00000000000d4000 (reserved)
[ 0.000000] modified: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000007ff60000 (usable)
[ 0.000000] modified: 000000007ff60000 - 000000007ff6a000 (ACPI data)
[ 0.000000] modified: 000000007ff6a000 - 000000007ff6b000 (reserved)
[ 0.000000] modified: 000000007ff6b000 - 000000007ff70000 (ACPI NVS)
[ 0.000000] modified: 000000007ff70000 - 0000000080000000 (reserved)
[ 0.000000] modified: 00000000ffb80000 - 00000000ffc00000 (reserved)
[ 0.000000] modified: 00000000fff80000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 377fe000 @ 7000-c000
[ 0.000000] RAMDISK: 37364000 - 37fef5b8
[ 0.000000] Allocated new RAMDISK: 008b5000 - 015405b8
[ 0.000000] Move RAMDISK from 0000000037364000 - 0000000037fef5b7 to 008b5000 - 015405b7
[ 0.000000] ACPI: RSDP 000f7a10 00014 (v00 TOSHIB)
[ 0.000000] ACPI: RSDT 7ff63fd8 00034 (v01 TOSHIB 750 00970814 MASM 06110000)
[ 0.000000] ACPI: FACP 7ff69d03 00084 (v02 TOSHIB 750 20030101 MASM 61100000)
[ 0.000000] ACPI: DSDT 7ff6400c 05CF7 (v01 TOSHIB A0007 20030806 MSFT 0100000E)
[ 0.000000] ACPI: FACS 7ff6bfc0 00040
[ 0.000000] ACPI: SSDT 7ff69d87 0021D (v01 TOSHIB A0007 00970814 MSFT 0100000E)
[ 0.000000] ACPI: DBGP 7ff69fa4 00034 (v01 TOSHIB 750 00970814 MASM 61100000)
[ 0.000000] ACPI: BOOT 7ff69fd8 00028 (v01 TOSHIB 750 00970814 MASM 06110000)
[ 0.000000] 1159MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] node 0 low ram: 00000000 - 377fe000
[ 0.000000] node 0 bootmap 00008000 - 0000ef00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00377fe000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [000009f800 - 0000100000] BIOS reserved ==> [000009f800 - 0000100000]
[ 0.000000] #5 [00008b1000 - 00008b4180] BRK ==> [00008b1000 - 00008b4180]
[ 0.000000] #6 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #7 [00008b5000 - 00015405b8] NEW RAMDISK ==> [00008b5000 - 00015405b8]
[ 0.000000] #8 [0000008000 - 000000f000] BOOTMAP ==> [0000008000 - 000000f000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007ff60
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0007ff60
[ 0.000000] On node 0 totalpages: 524027
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1542000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2319 pages used for memmap
[ 0.000000] HighMem zone: 294483 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:7fb80000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c2800000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519932
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=7286efdd-66b8-44fd-ae4c-1efbaec4547e ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 10482560 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007ff60)
[ 0.000000] Memory: 2046936k/2096512k available (4539k kernel code, 48312k reserved, 1928k data, 620k init, 1187208k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1396.531 MHz processor.
[ 0.008009] Calibrating delay loop (skipped), value calculated using timer frequency.. 2793.06 BogoMIPS (lpj=5586124)
[ 0.008039] Security Framework initialized
[ 0.008085] AppArmor: AppArmor initialized
[ 0.008097] Mount-cache hash table entries: 512
[ 0.008309] Initializing cgroup subsys ns
[ 0.008318] Initializing cgroup subsys cpuacct
[ 0.008324] Initializing cgroup subsys memory
[ 0.008340] Initializing cgroup subsys devices
[ 0.008344] Initializing cgroup subsys freezer
[ 0.008348] Initializing cgroup subsys net_cls
[ 0.008383] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.008388] CPU: L2 cache: 1024K
[ 0.008394] mce: CPU supports 5 MCE banks
[ 0.008417] Performance Events:
[ 0.008422] no APIC, boot with the "lapic" boot parameter to force-enable it.
[ 0.008425] no hardware sampling interrupt available.
[ 0.008429] p6 PMU driver.
[ 0.008438] ... version: 0
[ 0.008441] ... bit width: 32
[ 0.008444] ... generic registers: 2
[ 0.008447] ... value mask: 00000000ffffffff
[ 0.008450] ... max period: 000000007fffffff
[ 0.008454] ... fixed-purpose events: 0
[ 0.008457] ... event mask: 0000000000000003
[ 0.008465] Checking 'hlt' instruction... OK.
[ 0.025234] SMP alternatives: switching to UP code
[ 0.032635] Freeing SMP alternatives: 31k freed
[ 0.032651] ACPI: Core revision 20090903
[ 0.045374] ACPI: setting ELCR to 0200 (from 0c98)
[ 0.045512] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.045518] ftrace: allocating 21003 entries in 42 pages
[ 0.054730] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.054736] weird, boot CPU (#0) not listed by the BIOS.
[ 0.054739] SMP motherboard not detected.
[ 0.054742] Local APIC not detected. Using dummy APIC emulation.
[ 0.054745] SMP disabled
[ 0.054984] Brought up 1 CPUs
[ 0.054989] Total of 1 processors activated (2793.06 BogoMIPS).
[ 0.056034] CPU0 attaching NULL sched-domain.
[ 0.056234] devtmpfs: initialized
[ 0.056789] regulator: core version 0.5
[ 0.056865] NET: Registered protocol family 16
[ 0.057036] EISA bus registered
[ 0.057046] ACPI: bus type pci registered
[ 0.057366] PCI: PCI BIOS revision 2.10 entry at 0xfd981, last bus=4
[ 0.057369] PCI: Using configuration type 1 for base access
[ 0.058551] bio: create slab <bio-0> at 0
[ 0.059832] ACPI: EC: Look up EC in DSDT
[ 0.062670] ACPI Warning: Package List length (0x10) larger than NumElements count (0x5), truncated
[ 0.062678] (20090903/dsobject-515)
[ 0.064802] ACPI: Interpreter enabled
[ 0.064805] ACPI: (supports S0 S5)
[ 0.064820] ACPI: Using PIC for interrupt routing
[ 0.066690] [Firmware Bug]: ACPI: ACPI brightness control misses _BQC function
[ 0.071494] ACPI: Power Resource [PFAN] (off)
[ 0.071715] ACPI: No dock devices found.
[ 0.072045] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.072098] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xd0000000-0xdfffffff]
[ 0.072227] pci 0000:00:1d.0: reg 20 io port: [0x1800-0x181f]
[ 0.072284] pci 0000:00:1d.1: reg 20 io port: [0x1820-0x183f]
[ 0.072351] pci 0000:00:1d.7: reg 10 32bit mmio: [0xc0000000-0xc00003ff]
[ 0.072413] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.072420] pci 0000:00:1d.7: PME# disabled
[ 0.072513] pci 0000:00:1f.0: quirk: region 1000-107f claimed by ICH4 ACPI/GPIO/TCO
[ 0.072519] pci 0000:00:1f.0: quirk: region 1180-11bf claimed by ICH4 GPIO
[ 0.072545] pci 0000:00:1f.1: reg 10 io port: [0x00-0x07]
[ 0.072553] pci 0000:00:1f.1: reg 14 io port: [0x00-0x03]
[ 0.072562] pci 0000:00:1f.1: reg 18 io port: [0x00-0x07]
[ 0.072570] pci 0000:00:1f.1: reg 1c io port: [0x00-0x03]
[ 0.072579] pci 0000:00:1f.1: reg 20 io port: [0x1840-0x184f]
[ 0.072588] pci 0000:00:1f.1: reg 24 32bit mmio: [0x000000-0x0003ff]
[ 0.072635] pci 0000:00:1f.5: reg 10 io port: [0x1c00-0x1cff]
[ 0.072643] pci 0000:00:1f.5: reg 14 io port: [0x1880-0x18bf]
[ 0.072652] pci 0000:00:1f.5: reg 18 32bit mmio: [0xc0000c00-0xc0000dff]
[ 0.072660] pci 0000:00:1f.5: reg 1c 32bit mmio: [0xc0000800-0xc00008ff]
[ 0.072693] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
[ 0.072698] pci 0000:00:1f.5: PME# disabled
[ 0.072732] pci 0000:00:1f.6: reg 10 io port: [0x2400-0x24ff]
[ 0.072740] pci 0000:00:1f.6: reg 14 io port: [0x2000-0x207f]
[ 0.072781] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[ 0.072786] pci 0000:00:1f.6: PME# disabled
[ 0.072828] pci 0000:01:00.0: reg 10 32bit mmio: [0xc1000000-0xc1ffffff]
[ 0.072836] pci 0000:01:00.0: reg 14 32bit mmio pref: [0xe0000000-0xefffffff]
[ 0.072856] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.072915] pci 0000:00:01.0: bridge 32bit mmio: [0xc1000000-0xc1ffffff]
[ 0.072920] pci 0000:00:01.0: bridge 32bit mmio pref: [0xe0000000-0xefffffff]
[ 0.072967] pci 0000:02:07.0: reg 10 32bit mmio: [0xc2006000-0xc20067ff]
[ 0.072976] pci 0000:02:07.0: reg 14 32bit mmio: [0xc2000000-0xc2003fff]
[ 0.073020] pci 0000:02:07.0: supports D1 D2
[ 0.073023] pci 0000:02:07.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.073029] pci 0000:02:07.0: PME# disabled
[ 0.073063] pci 0000:02:08.0: reg 10 32bit mmio: [0xc2004000-0xc2004fff]
[ 0.073071] pci 0000:02:08.0: reg 14 io port: [0x3000-0x303f]
[ 0.073111] pci 0000:02:08.0: supports D1 D2
[ 0.073114] pci 0000:02:08.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.073120] pci 0000:02:08.0: PME# disabled
[ 0.073156] pci 0000:02:0a.0: reg 10 32bit mmio: [0xc2005000-0xc2005fff]
[ 0.073239] pci 0000:02:0b.0: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.073262] pci 0000:02:0b.0: supports D1 D2
[ 0.073265] pci 0000:02:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.073271] pci 0000:02:0b.0: PME# disabled
[ 0.073310] pci 0000:02:0d.0: reg 10 32bit mmio: [0xc2006800-0xc20069ff]
[ 0.073360] pci 0000:02:0d.0: supports D1 D2
[ 0.073364] pci 0000:02:0d.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.073370] pci 0000:02:0d.0: PME# disabled
[ 0.073399] pci 0000:00:1e.0: transparent bridge
[ 0.073405] pci 0000:00:1e.0: bridge io port: [0x3000-0x3fff]
[ 0.073411] pci 0000:00:1e.0: bridge 32bit mmio: [0xc2000000-0xc20fffff]
[ 0.073444] pci_bus 0000:00: on NUMA node 0
[ 0.073450] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.073503] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.073547] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIB._PRT]
[ 0.076390] ACPI: PCI Interrupt Link [LNKA] (IRQs *3 4 5 7 11)
[ 0.076553] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 *4 5 7 11)
[ 0.076686] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 11) *0, disabled.
[ 0.076848] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 *11)
[ 0.077007] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 *11)
[ 0.077168] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 7 11)
[ 0.077327] ACPI: PCI Interrupt Link [LNKG] (IRQs *10)
[ 0.077485] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 *7 11)
[ 0.077649] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.077656] vgaarb: loaded
[ 0.077835] SCSI subsystem initialized
[ 0.077903] libata version 3.00 loaded.
[ 0.078006] usbcore: registered new interface driver usbfs
[ 0.078024] usbcore: registered new interface driver hub
[ 0.078063] usbcore: registered new device driver usb
[ 0.078256] ACPI: WMI: Mapper loaded
[ 0.078260] PCI: Using ACPI for IRQ routing
[ 0.078486] NetLabel: Initializing
[ 0.078489] NetLabel: domain hash size = 128
[ 0.078492] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.078511] NetLabel: unlabeled traffic allowed by default
[ 0.078550] Switching to clocksource tsc
[ 0.080001] AppArmor: AppArmor Filesystem Enabled
[ 0.080001] pnp: PnP ACPI init
[ 0.080001] ACPI: bus type pnp registered
[ 0.081452] pnp: PnP ACPI: found 11 devices
[ 0.081456] ACPI: ACPI bus type pnp unregistered
[ 0.081462] PnPBIOS: Disabled by ACPI PNP
[ 0.081477] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.081482] system 00:00: iomem range 0xe0000-0xeffff could not be reserved
[ 0.081486] system 00:00: iomem range 0xf0000-0xfffff could not be reserved
[ 0.081491] system 00:00: iomem range 0x100000-0x7ff5ffff could not be reserved
[ 0.081496] system 00:00: iomem range 0x7ff60000-0x7ff6bfff could not be reserved
[ 0.081501] system 00:00: iomem range 0x7ff6c000-0x7ff6ffff could not be reserved
[ 0.081506] system 00:00: iomem range 0x7ff70000-0x7ff7ffff has been reserved
[ 0.081511] system 00:00: iomem range 0x7ff80000-0x7fffffff has been reserved
[ 0.081515] system 00:00: iomem range 0xffb80000-0xffbfffff has been reserved
[ 0.081520] system 00:00: iomem range 0xfff80000-0xffffffff has been reserved
[ 0.081534] system 00:0a: ioport range 0x1e0-0x1e7 has been reserved
[ 0.081539] system 00:0a: ioport range 0x480-0x48f has been reserved
[ 0.081544] system 00:0a: ioport range 0x680-0x6ff has been reserved
[ 0.081548] system 00:0a: ioport range 0x1000-0x107f has been reserved
[ 0.081553] system 00:0a: ioport range 0x10ac-0x10ac has been reserved
[ 0.081558] system 00:0a: ioport range 0x1100-0x111f has been reserved
[ 0.081562] system 00:0a: ioport range 0x1180-0x11bf has been reserved
[ 0.081567] system 00:0a: ioport range 0x4d0-0x4d1 has been reserved
[ 0.081572] system 00:0a: ioport range 0xe000-0xe07f has been reserved
[ 0.081577] system 00:0a: ioport range 0xe080-0xe0ff has been reserved
[ 0.081581] system 00:0a: ioport range 0xe400-0xe47f has been reserved
[ 0.081586] system 00:0a: ioport range 0xe480-0xe4ff has been reserved
[ 0.081591] system 00:0a: ioport range 0xe800-0xe87f has been reserved
[ 0.081595] system 00:0a: ioport range 0xe880-0xe8ff has been reserved
[ 0.081600] system 00:0a: ioport range 0xec00-0xec7f has been reserved
[ 0.081605] system 00:0a: ioport range 0xec80-0xecff has been reserved
[ 0.116382] pci 0000:01:00.0: BAR 6: can't allocate mem resource [0xf0000000-0xefffffff]
[ 0.116388] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.116392] pci 0000:00:01.0: IO window: disabled
[ 0.116397] pci 0000:00:01.0: MEM window: 0xc1000000-0xc1ffffff
[ 0.116403] pci 0000:00:01.0: PREFETCH window: 0xe0000000-0xefffffff
[ 0.116416] pci 0000:02:0b.0: CardBus bridge, secondary bus 0000:03
[ 0.116420] pci 0000:02:0b.0: IO window: 0x003400-0x0034ff
[ 0.116426] pci 0000:02:0b.0: IO window: 0x003800-0x0038ff
[ 0.116433] pci 0000:02:0b.0: PREFETCH window: 0x80000000-0x83ffffff
[ 0.116439] pci 0000:02:0b.0: MEM window: 0x88000000-0x8bffffff
[ 0.116445] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:02
[ 0.116450] pci 0000:00:1e.0: IO window: 0x3000-0x3fff
[ 0.116457] pci 0000:00:1e.0: MEM window: 0xc2000000-0xc20fffff
[ 0.116463] pci 0000:00:1e.0: PREFETCH window: 0x80000000-0x83ffffff
[ 0.116483] pci 0000:00:1e.0: setting latency timer to 64
[ 0.116494] pci 0000:02:0b.0: enabling device (0000 -> 0003)
[ 0.116752] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 3
[ 0.116756] PCI: setting IRQ 3 as level-triggered
[ 0.116762] pci 0000:02:0b.0: PCI INT A -> Link[LNKA] -> GSI 3 (level, low) -> IRQ 3
[ 0.116771] pci 0000:02:0b.0: setting latency timer to 64
[ 0.116777] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.116782] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.116786] pci_bus 0000:01: resource 1 mem: [0xc1000000-0xc1ffffff]
[ 0.116790] pci_bus 0000:01: resource 2 pref mem [0xe0000000-0xefffffff]
[ 0.116795] pci_bus 0000:02: resource 0 io: [0x3000-0x3fff]
[ 0.116799] pci_bus 0000:02: resource 1 mem: [0xc2000000-0xc20fffff]
[ 0.116803] pci_bus 0000:02: resource 2 pref mem [0x80000000-0x83ffffff]
[ 0.116807] pci_bus 0000:02: resource 3 io: [0x00-0xffff]
[ 0.116811] pci_bus 0000:02: resource 4 mem: [0x000000-0xffffffff]
[ 0.116815] pci_bus 0000:03: resource 0 io: [0x3400-0x34ff]
[ 0.116819] pci_bus 0000:03: resource 1 io: [0x3800-0x38ff]
[ 0.116824] pci_bus 0000:03: resource 2 pref mem [0x80000000-0x83ffffff]
[ 0.116828] pci_bus 0000:03: resource 3 mem: [0x88000000-0x8bffffff]
[ 0.116883] NET: Registered protocol family 2
[ 0.117028] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.117565] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.119020] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.120014] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.120019] TCP reno registered
[ 0.120213] NET: Registered protocol family 1
[ 0.120327] pci 0000:01:00.0: Boot video device
[ 0.120343] pci 0000:02:08.0: Firmware left e100 interrupts enabled; disabling
[ 0.120502] Simple Boot Flag at 0x36 set to 0x1
[ 0.120664] Scanning for low memory corruption every 60 seconds
[ 0.120839] audit: initializing netlink socket (disabled)
[ 0.120866] type=2000 audit(1378150354.117:1): initialized
[ 0.133930] Trying to unpack rootfs image as initramfs...
[ 0.149500] highmem bounce pool size: 64 pages
[ 0.149511] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.152171] VFS: Disk quotas dquot_6.5.2
[ 0.152276] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.157977] fuse init (API version 7.13)
[ 0.158144] msgmni has been set to 1680
[ 0.158493] alg: No test for stdrng (krng)
[ 0.158593] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.158598] io scheduler noop registered
[ 0.158601] io scheduler anticipatory registered
[ 0.158604] io scheduler deadline registered
[ 0.158688] io scheduler cfq registered (default)
[ 0.158867] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.158901] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.159031] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.159144] ACPI: Lid Switch [LID]
[ 0.159211] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.159218] ACPI: Power Button [PWRB]
[ 0.159287] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.159291] ACPI: Power Button [PWRF]
[ 0.161360] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.162145] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 4
[ 0.162150] PCI: setting IRQ 4 as level-triggered
[ 0.162157] serial 0000:00:1f.6: PCI INT B -> Link[LNKB] -> GSI 4 (level, low) -> IRQ 4
[ 0.162167] serial 0000:00:1f.6: PCI INT B disabled
[ 0.163631] brd: module loaded
[ 0.164372] loop: module loaded
[ 0.164499] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.164633] ata_piix 0000:00:1f.1: version 2.13
[ 0.164645] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
[ 0.164905] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 0.164909] PCI: setting IRQ 11 as level-triggered
[ 0.164915] ata_piix 0000:00:1f.1: PCI INT A -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 0.164972] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.169624] isapnp: Scanning for PnP cards...
[ 0.175091] scsi0 : ata_piix
[ 0.177606] scsi1 : ata_piix
[ 0.179116] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1840 irq 14
[ 0.179121] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1848 irq 15
[ 0.179702] Fixed MDIO Bus: probed
[ 0.179759] PPP generic driver version 2.4.2
[ 0.179851] tun: Universal TUN/TAP device driver, 1.6
[ 0.179855] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.179994] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.180280] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 7
[ 0.180285] PCI: setting IRQ 7 as level-triggered
[ 0.180292] ehci_hcd 0000:00:1d.7: PCI INT D -> Link[LNKH] -> GSI 7 (level, low) -> IRQ 7
[ 0.180315] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 0.180320] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 0.180374] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 0.180415] ehci_hcd 0000:00:1d.7: debug port 1
[ 0.184295] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 0.233897] ehci_hcd 0000:00:1d.7: irq 7, io mem 0xc0000000
[ 0.253543] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.253769] usb usb1: configuration #1 chosen from 1 choice
[ 0.253816] hub 1-0:1.0: USB hub found
[ 0.253831] hub 1-0:1.0: 4 ports detected
[ 0.253925] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.253951] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.254027] uhci_hcd 0000:00:1d.0: PCI INT A -> Link[LNKA] -> GSI 3 (level, low) -> IRQ 3
[ 0.254040] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.254045] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.254111] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.254144] uhci_hcd 0000:00:1d.0: irq 3, io base 0x00001800
[ 0.254282] usb usb2: configuration #1 chosen from 1 choice
[ 0.254320] hub 2-0:1.0: USB hub found
[ 0.254330] hub 2-0:1.0: 2 ports detected
[ 0.254705] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
[ 0.254712] uhci_hcd 0000:00:1d.1: PCI INT B -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 0.254720] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.254724] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.254773] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 0.254799] uhci_hcd 0000:00:1d.1: irq 11, io base 0x00001820
[ 0.254933] usb usb3: configuration #1 chosen from 1 choice
[ 0.254972] hub 3-0:1.0: USB hub found
[ 0.254983] hub 3-0:1.0: 2 ports detected
[ 0.255118] PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.263184] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.263200] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.265799] mice: PS/2 mouse device common for all mice
[ 0.265998] rtc_cmos 00:07: RTC can wake from S4
[ 0.266066] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0
[ 0.266087] rtc0: alarms up to one month, y3k, 114 bytes nvram
[ 0.266305] device-mapper: uevent: version 1.0.3
[ 0.266482] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.269058] device-mapper: multipath: version 1.1.0 loaded
[ 0.269064] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.269314] EISA: Probing bus 0 at eisa.0
[ 0.269323] Cannot allocate resource for EISA slot 1
[ 0.269327] Cannot allocate resource for EISA slot 2
[ 0.269331] Cannot allocate resource for EISA slot 3
[ 0.269348] EISA: Detected 0 cards.
[ 0.269352] cpuidle: using governor ladder
[ 0.269355] cpuidle: using governor menu
[ 0.270116] TCP cubic registered
[ 0.270394] NET: Registered protocol family 10
[ 0.271077] lo: Disabled Privacy Extensions
[ 0.271565] NET: Registered protocol family 17
[ 0.271606] Using IPI No-Shortcut mode
[ 0.271744] registered taskstats version 1
[ 0.272069] rtc_cmos 00:07: setting system clock to 2013-09-02 19:32:34 UTC (1378150354)
[ 0.272074] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.272077] EDD information not available.
[ 0.329851] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.421255] ata1.00: ATA-7: WDC WD1200VE-00KWT0, 01.03K01, max UDMA/100
[ 0.421262] ata1.00: 234441648 sectors, multi 16: LBA48
[ 0.430138] ata2.00: ATAPI: HL-DT-STCD-RW/DVD DRIVE GCC-4241N, 0T05, max UDMA/33
[ 0.430513] ata1.00: configured for UDMA/100
[ 0.445987] ata2.00: configured for UDMA/33
[ 0.681144] usb 1-3: new high speed USB device using ehci_hcd and address 3
[ 0.856946] isapnp: No Plug & Play device found
[ 0.857232] scsi 0:0:0:0: Direct-Access ATA WDC WD1200VE-00K 01.0 PQ: 0 ANSI: 5
[ 0.857502] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 0.857750] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
[ 0.857824] sd 0:0:0:0: [sda] Write Protect is off
[ 0.857828] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.857867] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.858080] sda:
[ 0.862647] scsi 1:0:0:0: CD-ROM HL-DT-ST RW/DVD GCC-4241N 0T05 PQ: 0 ANSI: 5
[ 0.876375] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[ 0.876383] Uniform CD-ROM driver Revision: 3.20
[ 0.876604] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 0.876718] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 0.886829] usb 1-3: configuration #1 chosen from 1 choice
[ 0.909954] sda1 sda2 sda3 < sda5 sda6 >
[ 0.939453] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.030452] Freeing initrd memory: 12845k freed
[ 1.049726] Freeing unused kernel memory: 620k freed
[ 1.050781] Write protecting the kernel text: 4540k
[ 1.050826] Write protecting the kernel read-only data: 1668k
[ 1.076532] udev: starting version 151
[ 1.128073] usb 2-1: new low speed USB device using uhci_hcd and address 2
[ 1.317173] usb 2-1: configuration #1 chosen from 1 choice
[ 1.424658] Linux agpgart interface v0.103
[ 1.446750] vga16fb: initializing
[ 1.446758] vga16fb: mapped to 0xc00a0000
[ 1.446905] fb0: VGA16 VGA frame buffer device
[ 1.465156] Initializing USB Mass Storage driver...
[ 1.465307] scsi2 : SCSI emulation for USB Mass Storage devices
[ 1.465564] usbcore: registered new interface driver usb-storage
[ 1.465569] USB Mass Storage support registered.
[ 1.465715] usb-storage: device found at 3
[ 1.465718] usb-storage: waiting for device to settle before scanning
[ 1.481878] agpgart-intel 0000:00:00.0: Intel 855PM Chipset
[ 1.501541] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 1.501546] e100: Copyright(c) 1999-2006 Intel Corporation
[ 1.501895] ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 11
[ 1.501902] e100 0000:02:08.0: PCI INT A -> Link[LNKE] -> GSI 11 (level, low) -> IRQ 11
[ 1.525801] e100 0000:02:08.0: PME# disabled
[ 1.534299] [Firmware Bug]: ACPI: ACPI brightness control misses _BQC function
[ 1.535431] acpi device:01: registered as cooling_device0
[ 1.535791] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:00/LNXVIDEO:00/input/input5
[ 1.536044] ACPI: Video Device [VGA] (multi-head: yes rom: yes post: no)
[ 1.546071] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 1.672448] usbcore: registered new interface driver hiddev
[ 1.673763] e100: eth0: e100_probe: addr 0xc2004000, irq 11, MAC addr 00:0e:7b:2a:1b:f0
[ 1.674118] ACPI: PCI Interrupt Link [LNKF] enabled at IRQ 3
[ 1.674125] ohci1394 0000:02:07.0: PCI INT A -> Link[LNKF] -> GSI 3 (level, low) -> IRQ 3
[ 1.727159] input: HID 04d9:0461 as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/input/input6
[ 1.727464] generic-usb 0003:04D9:0461.0001: input,hidraw0: USB HID v1.10 Mouse [HID 04d9:0461] on usb-0000:00:1d.0-1/input0
[ 1.727501] usbcore: registered new interface driver usbhid
[ 1.727631] usbhid: v2.6:USB HID core driver
[ 1.728061] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[3] MMIO=[c2006000-c20067ff] Max Packet=[2048] IR/IT contexts=[4/8]
[ 1.740177] Console: switching to colour frame buffer device 80x30
[ 2.270412] xor: automatically using best checksumming function: pIII_sse
[ 2.288016] pIII_sse : 3738.000 MB/sec
[ 2.288020] xor: using function: pIII_sse (3738.000 MB/sec)
[ 2.320469] device-mapper: dm-raid45: initialized v0.2594b
[ 2.554075] EXT4-fs (sda5): mounted filesystem with ordered data mode
[ 3.000215] ieee1394: Host added: ID:BUS[0-00:1023] GUID[0000390000b64489]
[ 6.465414] usb-storage: device scan complete
[ 6.466440] scsi 2:0:0:0: Direct-Access USB DISK 2.0 PMAP PQ: 0 ANSI: 0 CCS
[ 6.467129] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 6.468536] sd 2:0:0:0: [sdb] 2015232 512-byte logical blocks: (1.03 GB/984 MiB)
[ 6.469031] sd 2:0:0:0: [sdb] Write Protect is off
[ 6.469036] sd 2:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 6.469040] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 6.472529] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 6.472534] sdb: sdb1
[ 6.532768] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 6.532774] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 14.089316] Adding 721912k swap on /dev/sda6. Priority:-1 extents:1 across:721912k
[ 14.101399] udev: starting version 151
[ 14.560104] toshiba_acpi: Toshiba Laptop ACPI Extras version 0.19-dev-acpikeys
[ 14.560116] toshiba_acpi: HCI method: \_SB_.VALZ.GHCI
[ 14.561185] toshiba_acpi: Toshiba hotkeys are sent as ACPI events
[ 14.561189] toshiba_acpi: ktoshkeyd will check 2 times per second
[ 14.569019] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 14.602220] intel_rng: FWH not detected
[ 14.603292] toshiba_acpi: Dropped 0 keys from the queue on startup
[ 14.779252] parport_pc 00:09: activated
[ 14.779259] parport_pc 00:09: reported by Plug and Play ACPI
[ 14.779310] parport0: PC-style at 0x378 (0x778), irq 5, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 14.848600] lp: driver loaded but no devices found
[ 14.876354] lp0: using parport0 (interrupt-driven).
[ 14.879148] lib80211: common routines for IEEE802.11 drivers
[ 14.879154] lib80211_crypt: registered algorithm 'NULL'
[ 14.895300] ppdev: user-space parallel port driver
[ 14.933877] ieee80211: 802.11 data/management/control stack, git-1.1.13
[ 14.933883] ieee80211: Copyright (C) 2004-2005 Intel Corporation <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 15.393316] nvidia: module license 'NVIDIA' taints kernel.
[ 15.393323] Disabling lock debugging due to kernel taint
[ 16.217847] Synaptics Touchpad, model: 1, fw: 5.9, id: 0xf6eb1, caps: 0x804713/0x0
[ 16.217860] synaptics: Toshiba Portable PC detected, limiting rate to 40pps.
[ 16.283619] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input7
[ 16.600186] type=1505 audit(1378139570.827:2): operation="profile_load" pid=657 name="/sbin/dhclient3"
[ 16.600425] type=1505 audit(1378139570.827:3): operation="profile_load" pid=657 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 16.600552] type=1505 audit(1378139570.827:4): operation="profile_load" pid=657 name="/usr/lib/connman/scripts/dhclient-script"
[ 16.695991] type=1505 audit(1378139570.919:5): operation="profile_replace" pid=675 name="/sbin/dhclient3"
[ 16.696494] type=1505 audit(1378139570.923:6): operation="profile_replace" pid=675 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 16.696627] type=1505 audit(1378139570.923:7): operation="profile_replace" pid=675 name="/usr/lib/connman/scripts/dhclient-script"
[ 16.966827] type=1505 audit(1378139571.191:8): operation="profile_load" pid=778 name="/usr/share/gdm/guest-session/Xsession"
[ 17.027677] type=1505 audit(1378139571.251:9): operation="profile_replace" pid=718 name="/sbin/dhclient3"
[ 17.027904] type=1505 audit(1378139571.251:10): operation="profile_replace" pid=718 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 17.028084] type=1505 audit(1378139571.255:11): operation="profile_replace" pid=718 name="/usr/lib/connman/scripts/dhclient-script"
[ 17.130032] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.481018] ipw2100: Intel(R) PRO/Wireless 2100 Network Driver, git-1.2.2
[ 17.481025] ipw2100: Copyright(c) 2003-2006 Intel Corporation
[ 17.486166] ipw2100 0000:02:0a.0: PCI INT A -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 17.486871] ipw2100: Detected Intel PRO/Wireless 2100 Network Connection
[ 17.486898] ipw2100 0000:02:0a.0: firmware: requesting ipw2100-1.3.fw
[ 17.801234] Intel ICH 0000:00:1f.5: PCI INT B -> Link[LNKB] -> GSI 4 (level, low) -> IRQ 4
[ 17.801301] Intel ICH 0000:00:1f.5: setting latency timer to 64
[ 17.804342] yenta_cardbus 0000:02:0b.0: CardBus bridge found [1179:0001]
[ 17.842066] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 17.876398] nvidia 0000:01:00.0: power state changed by ACPI to D0
[ 17.876664] ACPI: PCI Interrupt Link [LNKG] enabled at IRQ 10
[ 17.876668] PCI: setting IRQ 10 as level-triggered
[ 17.876675] nvidia 0000:01:00.0: PCI INT A -> Link[LNKG] -> GSI 10 (level, low) -> IRQ 10
[ 17.878067] NVRM: loading NVIDIA UNIX x86 Kernel Module 173.14.22 Sun Nov 8 20:26:31 PST 2009
[ 17.932453] yenta_cardbus 0000:02:0b.0: ISA IRQ mask 0x0000, PCI irq 3
[ 17.932461] yenta_cardbus 0000:02:0b.0: Socket status: 30000007
[ 17.932468] pci_bus 0000:02: Raising subordinate bus# of parent bus (#02) from #03 to #06
[ 17.932487] yenta_cardbus 0000:02:0b.0: pcmcia: parent PCI bridge I/O window: 0x3000 - 0x3fff
[ 17.932494] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3000-0x3fff: clean.
[ 17.932870] yenta_cardbus 0000:02:0b.0: pcmcia: parent PCI bridge Memory window: 0xc2000000 - 0xc20fffff
[ 17.932875] yenta_cardbus 0000:02:0b.0: pcmcia: parent PCI bridge Memory window: 0x80000000 - 0x83ffffff
[ 18.248919] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean.
[ 18.249938] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: clean.
[ 18.250374] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 18.250760] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 18.251325] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 19.080033] AC'97 1 does not respond - RESET
[ 19.080240] AC'97 1 access is not valid [0xffffffff], removing mixer.
[ 19.080248] Unable to initialize codec #1
[ 19.136048] intel8x0_measure_ac97_clock: measured 55466 usecs (2672 samples)
[ 19.136055] intel8x0: clocking to 48000
[ 20.824750] agpgart-intel 0000:00:00.0: AGP 2.0 bridge
[ 20.824768] agpgart-intel 0000:00:00.0: putting AGP V2 device into 4x mode
[ 20.824809] nvidia 0000:01:00.0: putting AGP V2 device into 4x mode
[ 31.413024] __ratelimit: 9 callbacks suppressed
[ 31.413031] type=1505 audit(1378139585.639:15): operation="profile_load" pid=815 name="/usr/bin/evince"
[ 31.415179] type=1505 audit(1378139585.639:16): operation="profile_load" pid=815 name="/usr/bin/evince-previewer"
[ 31.428912] type=1505 audit(1378139585.655:17): operation="profile_load" pid=815 name="/usr/bin/evince-thumbnailer"
[ 34.056235] type=1505 audit(1378139588.283:18): operation="profile_load" pid=978 name="/usr/lib/cups/backend/cups-pdf"
[ 34.056607] type=1505 audit(1378139588.283:19): operation="profile_load" pid=978 name="/usr/sbin/cupsd"
[ 35.239010] type=1505 audit(1378139589.463:20): operation="profile_load" pid=1107 name="/usr/sbin/tcpdump"
[ 38.600344] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 42.457335] lib80211_crypt: registered algorithm 'CCMP'
[ 42.498585] padlock: VIA PadLock not detected.
[ 49.508044] eth1: no IPv6 routers present
[ 66.125472] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 187.624388] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 219.127647] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 306.982942] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 316.979028] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 323.218345] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 386.966737] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 425.135642] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 425.600428] halcmd[2005]: segfault at 8 ip 003956bc sp bfcb1890 error 6 in liblinuxcnchal.so.0[390000+8000]
[ 425.604308] halcmd[2006]: segfault at 8 ip 0053c6bc sp bf831a00 error 6 in liblinuxcnchal.so.0[537000+8000]
[ 425.624178] halcmd[2009]: segfault at 8 ip 001f26bc sp bf9e65b0 error 6 in liblinuxcnchal.so.0[1ed000+8000]
[ 425.854634] halcmd[2013]: segfault at 8 ip 005d96bc sp bf9e58b0 error 6 in liblinuxcnchal.so.0[5d4000+8000]
[ 426.064853] halcmd[2017]: segfault at 8 ip 00ad66bc sp bf950c00 error 6 in liblinuxcnchal.so.0[ad1000+8000]
[ 426.275700] halcmd[2021]: segfault at 8 ip 00c166bc sp bfa9bb90 error 6 in liblinuxcnchal.so.0[c11000+8000]
[ 426.486001] halcmd[2025]: segfault at 8 ip 003276bc sp bfbd5c00 error 6 in liblinuxcnchal.so.0[322000+8000]
[ 426.698042] halcmd[2029]: segfault at 8 ip 002fc6bc sp bf90b7a0 error 6 in liblinuxcnchal.so.0[2f7000+8000]
[ 426.909216] halcmd[2033]: segfault at 8 ip 00c656bc sp bfca4390 error 6 in liblinuxcnchal.so.0[c60000+8000]
[ 427.119396] halcmd[2037]: segfault at 8 ip 002096bc sp bfb42320 error 6 in liblinuxcnchal.so.0[204000+8000]
[ 648.646470] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 650.799583] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 651.955254] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 652.980909] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 653.906276] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 654.778159] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 655.756243] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 691.009929] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 2364.666403] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 2365.025597] __ratelimit: 2 callbacks suppressed
[ 2365.025604] halcmd[2951]: segfault at 8 ip 00bbd6bc sp bfcc6d60 error 6 in liblinuxcnchal.so.0[bb8000+8000]
[ 2365.029473] halcmd[2952]: segfault at 8 ip 006536bc sp bfc7bc00 error 6 in liblinuxcnchal.so.0[64e000+8000]
[ 2365.039295] halcmd[2955]: segfault at 8 ip 0052e6bc sp bfabf630 error 6 in liblinuxcnchal.so.0[529000+8000]
[ 2365.249609] halcmd[2959]: segfault at 8 ip 00f8a6bc sp bfb06b60 error 6 in liblinuxcnchal.so.0[f85000+8000]
[ 2365.459924] halcmd[2963]: segfault at 8 ip 0062f6bc sp bfb28db0 error 6 in liblinuxcnchal.so.0[62a000+8000]
[ 2365.670082] halcmd[2967]: segfault at 8 ip 009006bc sp bff5ed30 error 6 in liblinuxcnchal.so.0[8fb000+8000]
[ 2365.879632] halcmd[2971]: segfault at 8 ip 003d66bc sp bfcf64c0 error 6 in liblinuxcnchal.so.0[3d1000+8000]
[ 2366.091733] halcmd[2975]: segfault at 8 ip 006a66bc sp bfca4790 error 6 in liblinuxcnchal.so.0[6a1000+8000]
[ 2366.303797] halcmd[2979]: segfault at 8 ip 00cac6bc sp bf8efae0 error 6 in liblinuxcnchal.so.0[ca7000+8000]
[ 2366.514089] halcmd[2983]: segfault at 8 ip 00cfa6bc sp bfb95010 error 6 in liblinuxcnchal.so.0[cf5000+8000]
Last edit: 03 Sep 2013 00:24 by dimigav.
03 Sep 2013 02:00 #38440 by PCW
Replied by PCW on topic Using linuxcnc
The problem is this:
See this link for a solution:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl..._t_run_missing_lapic
04 Sep 2013 21:24 #38468 by dimigav
Replied by dimigav on topic Using linuxcnc
Thank you very much...
This problem solved...
