Toggle PYVCP panel visibility in axis
- lars
05 Nov 2018 21:47 #120043
by lars
Toggle PYVCP panel visibility in axis was created by lars
Hello.
I have a small screen (1024x768) and the PYVCP panel in Axis can up take a lot of space. When using bigger GLADEVCP tabs (e.g. a camera view or probe panel) there is not enough space left and the tabs are cut off and only partially visible.
I think it would be a nice to be able to toggle the visibility of the PYVCP panel. I wrote a small patch that adds a keyboard shortcut ('e' because nearly every sensible key is already in use) to do just that. Unfortunately I did not find how to modify the menu in Axis so I could not add a menu entry and submit a proper pull request.
Here is the really small patch for the keyboard shortcut:
I would appreciate it if someone could tell me where I can find the menu code. I grepped through the whole repository and did not match any menu strings.
Thanks a lot,
Lars
--- axis.orig 2018-06-18 23:26:11.000000000 +0200
+++ axis 2018-11-05 22:34:12.137464149 +0100
@@ -229,6 +229,7 @@
("#", _("toggle Relative/Machine")),
(_("Ctrl-Space"), _("Clear notifications")),
(_("Alt-F, M, V"), _("Open a Menu")),
+ ("E", _("toggle PYVCP panel visibility")),
@@ -2569,6 +2570,13 @@
else:
commands.set_view_z()
+ def toggle_vcp_frame(*args):
+ if vcp_frame.winfo_ismapped():
+ vcp_frame.grid_remove()
+ else:
+ vcp_frame.grid(row=0, column=4, rowspan=6, sticky="nw", padx=4, pady=4)
+ o.tkRedraw()
def axis_activated(*args):
if not hal_present: return # this only makes sense if HAL is present on this machine
comp['jog.x'] = vars.current_axis.get() == "x"
@@ -3263,6 +3271,8 @@
f.grid(row=0, column=4, rowspan=6, sticky="nw", padx=4, pady=4)
vcpparse.filename = vcp
vcpparse.create_vcp(f, comp)
+ vcp_frame = f
+ root_window.bind("e", commands.toggle_vcp_frame)
comp.ready()
gladevcp = inifile.find("DISPLAY", "GLADEVCP")I would appreciate it if someone could tell me where I can find the menu code. I grepped through the whole repository and did not match any menu strings.
Thanks a lot,
Lars
- lars
05 Nov 2018 22:28 #120050
by lars
Replied by lars on topic Toggle PYVCP panel visibility in axis
Found it in axis.tcl.
I will see if I can understand enough TCL to change this properly.
- pl7i92
- Thank you received: 358
02 Mar 2019 14:30 #127513
by pl7i92
Replied by pl7i92 on topic Toggle PYVCP panel visibility in axis
you may think of filing a Git patch to get other users also a benefit of your work if i understand correctly you implemented this function
- phillc54
- Thank you received: 2100
03 Mar 2019 05:52 #127566
by phillc54
Replied by phillc54 on topic Toggle PYVCP panel visibility in axis
This feature does already exist in master branch.
Cheers, Phill
Cheers, Phill
- pl7i92
03 Mar 2019 07:48 #127571
by pl7i92
that is Best to Know
If You work with it
Can you PLEASE write a wiki entrence of how to do it
wiki.linuxcnc.org
If You work with it
wiki.linuxcnc.org
- phillc54
04 Mar 2019 00:38 #127644
by phillc54
If you want to try master branch without removing your existing 2.7 installation then you could install a run in place version as described
here
, there is also a good step by step description
here
Running linuxcnc from a rip build installed as above can also be done by:Or you could make a desktop launcher similar to:
Another option is to install a precompiled package from the buildbot as described here . This option will remove your existing 2.7 version.
Cheers, Phill.
$ ~/linuxcnc-dev/scripts/linuxcnc ~/linuxcnc/configs/name_of_configuration/name_of_ini_file.ini[Desktop Entry]
Version=1.0
Type=Application
Terminal=true
Exec=/home/username/linuxcnc-dev/scripts/linuxcnc /home/username/linuxcnc/configs/axis/axis_mm.ini
Name=My CNC Machine
Icon=/home/username/linuxcnc-dev/linuxcncicon.pngAnother option is to install a precompiled package from the buildbot as described here . This option will remove your existing 2.7 version.
Cheers, Phill.
