Error opening xml file
- Buddy002
15 Apr 2019 21:42 #130934
by Buddy002
Error opening xml file was created by Buddy002
I had a working system until I ran the config wizard in order to change the homing method. The error that I am having now is loading the xml file which describe
s the right side axis panel.
Pyvcp_panel.xml describes the right side panel, Debug is contains the error. This pyvcp_panel has run before I ran the wizard.
- Grotius
- Thank you received: 2349
15 Apr 2019 21:50 #130936
by Grotius
Replied by Grotius on topic Error opening xml file
A little advise,
Before updating, save your current files !
Reverse engeneering can be a hard time.
It looks like : pyvcp-panel.xml:1: Unknown command '<?xml'
Is it the - sign at line one? Maybe line two is also invoked with the issue....
- Thank you received: 2181
16 Apr 2019 06:11 #130968
Replied by cmorley on topic Error opening xml file
I'm not exactly sure what is wrong but the commands:
make all the other commands into comments.
Chris M
Chris M
16 Apr 2019 06:15 #130969
also did you edit the file with a windows machine and have the wrong end-of-line character?
Long shot but could be a problem.
Chris M
Chris M
- Buddy002
25 Apr 2019 20:43 #131885
by Buddy002
Replied by Buddy002 on topic Error opening xml file
I ended up reinstalling linuxcnc 27.14 and the problem went away. Now on the new install it won't recognize signals like Clamp which worked before the reinstall. I have run into using text editors before in my working life. There are text editors out there that do not have formatting unprintable ASCI code attached to their data. On this project I have been using Mousepad which seems to work.
Time to create page: 0.293 seconds
