- Thank you received: 5334
PCW wrote: Sounds a bit more like a missing/unconnected field common/ground so as soon as you enable the drives or turn on a relay, field common is pulled up to +24V
andypugh wrote:
Mike@CNCproCuts.com wrote: the 7i84 inputs will have names like "hm2_5i25.0.7i84.0.0.input-00"
You should be able to find them in Halshow
I had not connected the VIN yet ... now I see it so thanks
