Axis not doing anything
  • phoenix
  • phoenix's Avatar Topic Author
  • Premium Member
  • Premium Member
15 May 2019 13:46 #133837 by phoenix
Axis not doing anything was created by phoenix
my axes are running in stepconf when i tested but after that i started axis gui and it does nothing hal shows all pins ok what should i do
also i want to add touch probe in axis or gmoccapy did anyone know how to do it
any help will be greatly aprreciated
15 May 2019 14:53 #133843 by pl7i92
Replied by pl7i92 on topic Axis not doing anything
if on stepconf all is running AND You SAFED it at the END -> DONE
you may have started the Wrong configuration
if the wizard can run the Axes it may be also a charge pump involved as all pins not configurerd are in high state
and your charge pump will block it
15 May 2019 15:37 #133850 by cmorley
Replied by cmorley on topic Axis not doing anything
check that simulated hardware checkbox is not checked in stepconf on the START page.
Chris M
  • phoenix
  • Premium Member
  • Premium Member
15 May 2019 15:49 #133851 by phoenix
Replied by phoenix on topic Axis not doing anything
thanks sir that helps
Time to create page: 0.252 seconds
