External corner lock signal
- phoenix
20 May 2019 00:41 #134315
by phoenix
External corner lock signal was created by phoenix
Hii guys...
I want external corner lock signal to give to my thc
My thc works on start pause and corner lock signal
I already figured out external start and pause switch
Ibwant to do the same for corner lock
I am using my own thc
Any ideas how i lt can be done....
Regards
Regards
- pl7i92
- Thank you received: 358
20 May 2019 06:33 #134331
by pl7i92
Replied by pl7i92 on topic External corner lock signal
Always 2 Posts for the Same Question BAD Behavior
you can USE motion.in-position for that
but that will always act on move fiished
THC workes on VOLTIGE of the Plasma
it is 80USD as of a TGC200 or a 200USD Proma UP/Down
it corrects on its own mesurment no need to be programmed
just signals to the contoller move up or move down
# Set up the Encoder for the THC
setp encoder.0.counter-mode 1
# added by tc
net freq-in parport.0.pin-11-in => encoder.0.phase-A
net thc-vel-in encoder.0.velocity => thc.encoder-vel
# these will need to be adjusted
setp thc.scale-offset 119000
setp thc.vel-scale 0.00037866834
setp thc.velocity-tol 100
setp thc.voltage-tol 1.0
I think it also needs this for z-axis:
# position command and feedback hijacked by thc comp
net emcmot.02.pos-cmd thc.z-pos-in <= axis.2.motor-pos-cmd
net thc-pos-cmd thc.z-pos-out => stepgen.2.position-cmd
net motor.02.pos-fb axis.2.motor-pos-fb <= thc.z-fb-out Please Log in or Create an account to join the conversation.
- Thank you received: 4153
20 May 2019 06:50 #134335
There is a corner lock component I wrote here.
forum.linuxcnc.org/plasma-laser/32658-thc-cornerlock-component
Assuming you are making an external THC, you would use the output pin to turn on a signal to your hardware to tell you to stop THC adjustment.
Note that you need to work on the feedrate sent from Gcode. You could use a remap command to send that to a motion analog pin with M67 or M68 and use that pin as the input to the corner lock component.
Replied by rodw on topic External corner lock signal
Hii guys...
Regards
Time to create page: 0.349 seconds
