How to remove G54, G92 and TLO readouts from axis screen
  • jeffgar2000@gmail.com
  • Junior Member
  • Junior Member
21 Sep 2019 04:21 #145731 by jeffgar2000@gmail.com
How to remove G54, G92 and TLO readouts from axis screen was created by jeffgar2000@gmail.com
This is probably simple but I have spent a ton of time trying to figure out how to remove the G54, G92 and TLO readouts from the axis screen with no luck.
Can somebody please tell me where that configuration is so I can change it.
Those readouts cover way too much of my screen and I really don't need them.
Jeff
21 Sep 2019 05:30 #145732 by cmorley
open AXIS, select view drop down. unselect show offsets
Chris
  • Junior Member
  • Junior Member
21 Sep 2019 14:01 #145749 by jeffgar2000@gmail.com
Replied by jeffgar2000@gmail.com on topic How to remove G54, G92 and TLO readouts from axis screen
Well there you go. When you spend hours trying to figure out how to modify config files by hand and can't get it, use the menu option. I never even consider that since I was so focused on some kind of config file to do it.
Thanks for pointing that out.
Jeff
21 Sep 2019 23:23 #145796 by cmorley
No problem - There is a lot to digest when first starting out with linuxcnc!
Chris
Time to create page: 0.146 seconds
