Pyvcp in tab Manual
13 Oct 2019 09:34 #147807 by nkp
Pyvcp in tab Manual was created by nkp
I want (for myself) to change Axis a bit .
I'll post some of the questions in this thread hoping for help.
How to place widgets Pyvcp in tab Manual (for example) ? (or other )
it's here:
github.com/LinuxCNC/linuxcnc/blob/master...cripts/axis.py#L3810
but if I change thise code :
if vcp:
        import vcpparse
        comp.setprefix("pyvcp")
        #try:
        f = Tkinter.Frame(widgets.tabs)
        #f = Tkinter.Frame(root_window)
        f.grid(row=0, column=0)
        vcpparse.filename = vcp
        vcpparse.create_vcp(f, comp)
        #except :
            #print "error Tkinter.Frame(widgets.tabs)"
- Axis freezes
placing elements (f.grid(row=0, column=0))for now never mind
14 Oct 2019 07:06 #147854 by pl7i92
Replied by pl7i92 on topic Pyvcp in tab Manual
why dont you use qtpyvcp there you can setup your frames where and how you like all open in color shape and size
modifying the simple ayis is not the way youshoudt work no updates anymore
and pyvcp is set fixed to its position on screen it has all the stuff you need there even images
14 Oct 2019 07:28 #147858 by nkp
Replied by nkp on topic Pyvcp in tab Manual
for different projects - different conditions =)
Of course I will use Qt (and have already tried).
But for now minimalistic GUI is required.
19 Oct 2019 06:36 #148290 by nkp
I tried using the bar (Pyvcp widget) to override the feed in Axis,
and toggle_show_pyvcppanel like in master.
Warning: Spoiler!
Time to create page: 0.423 seconds
