PWM not working - 7i96
- jools
- Thank you received: 15
18 Nov 2019 12:27 #150575
by jools
Manual spindle speed controll keys not showing on AXIS - 7i96 was created by jools
As above I seem to have lost my spindle speed control keys. HAL and INI attached for reference.
Thanks Jools
Thanks Jools
- jools
18 Nov 2019 13:45 - 18 Nov 2019 13:47 #150579
by jools
Replied by jools on topic Manual spindle speed controll keys not showing on AXIS - 7i96
Seemed top have sorted it
did a PNC conf for a 7176e and compared them and added this below.
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
This made the buttons show up so will try further. Might not need all of those though so if I don't please let me know.
1 thought. My spindle is PWM driven so do I need the spindle-vel commands? My .ini already has the below:
setp hm2_7i96.0.pwmgen.00.output-type 1
setp hm2_7i96.0.pwmgen.00.scale [SPINDLE]MAX_RPM
setp hm2_7i96.0.pwmgen.pwm_frequency [SPINDLE]PWM_FREQUENCY
Jools
Jools
Last edit: 18 Nov 2019 13:47 by jools.
- jools
18 Nov 2019 13:55 #150580
by jools
with those added I can click the buttons to start the spindle but the PWM output from the 7i96 doesn't waver from -5v.
Any thoughts?
Jools
Any thoughts?
Jools
- Thank you received: 2181
19 Nov 2019 07:40 #150611
Replied by cmorley on topic Manual spindle speed controll keys not showing on AXIS - 7i96
AXIS decides to show the spindle buttons by looking to see if a signal is connected to a certain pin ( I forget which one logically spinde.0.on)
You have connected a signal to these pins but not connected the signal to a corresponding pin. Ie a driver pin to a signal to a driven pin.
Ie spindle.0.on will be set true by AXIS so the signal spindle-enable will go true but
that signal goes nowhere.
Surely the 7i96 configuration program can connect the pins for you.
Chris
Chris
- jools
19 Nov 2019 08:27 - 19 Nov 2019 10:57 #150612
by jools
Replied by jools on topic PWM not working - 7i96
Hi Chris
That’s what I thought, but unless I’m doing something wrong on the hardware end I’m at a loss.
I set this up with the 7i96 configuration tool and it produced the first attached ini and Hal flies but no buttons. Researching this and comparing it with a fake pncconf setup for a 7i76 gave me the idea I need to Hal net commands but it still seems not to work.
I’ll investigate the hardware end and try some more settings today but with Hal I’m guessing; I grasp the concept loosely but when it comes to details I don’t have the skills.
Any more help from anyone would be great.
Jools
Jools
Last edit: 19 Nov 2019 10:57 by jools.
22 Nov 2019 13:13 #150911
Replied by andypugh on topic PWM not working - 7i96
The bits of Axis that show/hide spindle buttons are here:
github.com/LinuxCNC/linuxcnc/blob/master...cripts/axis.py#L4039
It is possible that I messed something up when I changed _all_ the spindle-related pin names in 2.8, though.
The following user(s) said Thank You: jools
Time to create page: 0.162 seconds
