simulation
6 years 11 months ago - 6 years 11 months ago #151272 by RobotMatic
Replied by RobotMatic on topic simulation
I am usually working with milling machines, the simulation generally in axis is as a quick test, because it was already done in a Cam system. Last Friday I had the need to program a compensated trajectory on a very large lathe that assembled with linuxcnc, and I had to remove the piece to be able to test the program until I could make the compensated trajectory work well.
It is there that I realized that you cannot test programs on Linux with Axis. I had not noticed it before.
I usually program Fanuc-Fagor-Hass, etc. and I have always simulated the programs on foot. I never realized this in Linuxcnc
It occurs to me that I could save the state of linuxcnc before when I request the simulation mode, disconnect the outside world, and when I return to the execution mode to recover the state prior to the simulation request. as if it were a call to an interruption in microcontrollers.
It would be interesting to have this type of function.
Last edit: 6 years 11 months ago by RobotMatic.
6 years 11 months ago #151300 by tommylight
Replied by tommylight on topic simulation
Again, the first answer can do all you are asking for.
6 years 11 months ago #151301 by RobotMatic
You tell me that the solution is to have two linuxcnc working in the same machine, one as a simulator and another functional?
6 years 11 months ago #151302 by Todd Zuercher
Replied by Todd Zuercher on topic simulation
I think so, but the problem is they could not run both simultaneously. My suggestion of putting the sim in a virtual machine would allow them to run side by side. (Provided you could find a PC that could handle it without screwing up your latency too much.)
6 years 11 months ago #151304 by RobotMatic
I can't believe your comments, but I respect them. Thanks for them, I hope linuxcnc in the future the developers can give you a more professional approach.
It is very difficult to propose improvements
It is the second time that happens to me, the first one was with the tool radius compensation, what the developers say is fine, in cnc technology it is a big mistake, the compensation loses a segment of the trajectory at the entrance, and now this. The result is always a cheap alternative, not a professional one.
Thank you all, I will continue my way
6 years 11 months ago #151305 by tommylight
RobotMatic wrote: You tell me that the solution is to have two linuxcnc working in the same machine, one as a simulator and another functional?
Yes.
you can have many different machines on one pc. Or as many sim's as you like.
And if you want to have the machine working while you are testing something else, do it on a virtual box, as Todd mentioned.
Time to create page: 0.073 seconds
