Losing G54 position ??
6 years 9 months ago #154174 by Niko
Replied by Niko on topic Losing G54 position ??
The deviation varies a lot . From 0.5mm to a few mm . the screw is 10mm pitch but the operator has never seen a deviation of exactly 10mm . So the home switch is not tripped a thread early .
I'll try to run some more experiments this week .
Is there a possibility linuxcnc isn't saving properly ?
6 years 9 months ago #154175 by cmorley
Replied by cmorley on topic Losing G54 position ??
Most anything is possible - but that is very unlikely.
It sounds like mechanical to me - though a few mm is an awful lot.
Is this new behaivour or it's always been like that?
What type of encoders are you using?
Chris
6 years 9 months ago - 6 years 9 months ago #154201 by Niko
It's been like that for quite some time . And I've had the chance to check everything mechanical . I've had my doubts about encoders but everything checks out fine .
The machine is a mori seiki with red hat fanuc drives . The original drives were replaced for a set of drives manufactured locally, that accept the weird fanuc signal . Output on these is not that difficult to use A B and C are standart . Only the commutation signals are a bit odd and are not differential .
The machine holds tolerances very well . I've personally checked motor couplings and they are solid . Bearings on the screw are good .
Cheers
P.S. I'm not entirely sure but I believe the problem gets worse if the computer is turned off incorrectly .
Last edit: 6 years 9 months ago by Niko.
6 years 9 months ago - 6 years 9 months ago #154229 by Niko
I ran a couple of experiments .
If power is turned off while linuxcnc is running it wipes the .var file clean . Nothing in it . And as lcnc is started it writes a file with all parameters = 0 .
Is this normal ?
machine runs 2.7.15 (updated today) on debian 9 with a mesa ethernet board .
P.S. What is the relationship between the .var and .var.bak files ? When is the bak file saved ?
Any details around the backup would be helpful .
6 years 9 months ago #154372 by andypugh
Replied by andypugh on topic Losing G54 position ??
An experiment I have never thought to do is to look at the timestamps of the .var file, to see if it is written during machine up-time (for example after a touch-off) or only at shut down.
I wonder if the "wrong" offsets might match the right ones from a previous day, and the whole problem is with the .var file not being written for whatever reason?
6 years 9 months ago #154410 by Niko
Where and how can I have a look at these ?
And how can the write time be changed ?
Time to create page: 0.146 seconds
