Change Tool Cone Size in Axis
- Thank you received: 2181
03 Mar 2020 22:34 #159119
Replied by cmorley on topic Change Tool Cone Size in Axis
Pushed to 2.8 and master - a few hours to get through the buildbot
under the [DISPLAY] heading:
CONE_BASESIZE = .25
numbers 2 - .025
Chris
CONE_BASESIZE = .25
numbers 2 - .025
Chris
The following user(s) said Thank You: phillc54, chimeno, tommylight, rodw
- Thank you received: 4149
03 Mar 2020 23:08 #159120
Chris, great thanks! I love it when ideas discussed on the forum become features in LInuxcnc. Its just the power of open source at work!
I'm due to rebuild my Plasmac config, so I'll give it a whirl in the next couple of days.
Replied by rodw on topic Change Tool Cone Size in Axis
CONE_BASESIZE = .25
numbers 2 - .025
Chris
- phillc54
- Thank you received: 2100
04 Mar 2020 02:43 #159139
by phillc54
Replied by phillc54 on topic Change Tool Cone Size in Axis
That works a treat Chris, thanks.
Thanks for pushing the PyVCP stuff as well.
04 Mar 2020 03:51 #159145
It's like we are all a team!
Love it when a plan comes together...
The following user(s) said Thank You: phillc54, tommylight, rodw
- mmt
04 Mar 2020 16:47 #159202
by mmt
Replied by mmt on topic Change Tool Cone Size in Axis
Glad I could help.... hahahahaha
Thanks Chris
Thanks Chris
- Roguish
- Thank you received: 31
18 Apr 2020 15:27 #164471
by Roguish
Replied by Roguish on topic Change Tool Cone Size in Axis
Is this also pushed up into Master?
if not, could you please...
Thanks.
Thanks.
18 Apr 2020 15:41 #164472
It's in master.
- rducky5
01 Feb 2022 21:48 #233746
by rducky5
Replied by rducky5 on topic Change Tool Cone Size in Axis
I have been trying to adjust the cone size in plasmac but this setting seems to have no effect. Do you know if plasmac overrides this config somewhere?
- Clive S
- Thank you received: 486
01 Feb 2022 22:34 #233750
by Clive S
Have you seen this:- forum.linuxcnc.org/21-axis/38485-change-...axis?start=10#159119
Replied by Clive S on topic Change Tool Cone Size in Axis
- rducky5
02 Feb 2022 13:41 #233797
by rducky5
Yes, I did see that setting and it seems to be working with axis but does not have an impact when using gmoccapy. I even found the code in glcannon.py but hard coding that doesn't have an impact
Time to create page: 0.123 seconds
