Grids with really wide axis range
23 Jul 2020 03:14 #175457 by Nico2017
Grids with really wide axis range was created by Nico2017
Hi all,
just a post to comment on something I noticed in case someone encounters the same thing.
During the development of a XYZ gantry machine, I did not noticed it initially but I realized down the line that the Grid and the X and Y axis limit (displayed in dashed red) were not displayed anymore into the Axis preview, even in my Z orthogonal top view.
I thought that the issue was coming from the GRIDS = in the [DISPLAY] section in the ini file. Actually the issue was the fact that in the ini file in my [AXIS_Z] section the MIN_LIMIT and MAX_LIMIT were set really high (-90000 to 90000 due to an initial scaling during the development). I believe the grid view gets affected by the depth of the back plane it is projected on associated to the min Z limit in my case. The red outline showing the maximum machine domain was also missing.
Putting back MIN_LIMIT and MAX_LIMIT to smaller values solved the issue and I can see again my grid and the machine limits which is really useful.
I hope this could help someone one day facing the same issue.
Nicolas
The following user(s) said Thank You: phillc54, tommylight
23 Jul 2020 11:48 #175525 by tommylight
Replied by tommylight on topic Grids with really wide axis range
Thanks for reporting that, i never noticed that since mostly i use +300 to -300mm for Z axis.
Time to create page: 0.316 seconds
