[solved]Weird coordinate position display
- Stormholt
- Thank you received: 8
02 Feb 2021 15:46 - 08 Mar 2021 14:26 #197438
by Stormholt
[solved]Weird coordinate position display was created by Stormholt
Hello LinuxCNC community
First time poster/ 2 day old linuxcnc user
Since my installation my coordinate position display on the preview tab has looked weird, meaning different from my boss. Please see the attached image.
I primarily used this guide
I'm on a Ubuntu 20.04, and have linuxcnc-uspace version 1:2.8.1.44.g60f3d7
The numbers change in accordance to the machines position, however the small boxes give me no readable information about the actual coordinates. So far I have turned to the DRO tab for that, however I would like to have decimal numbers there instead of the boxes.
What should i do?
Thanks in advance.
What should i do?
Thanks in advance.
Last edit: 08 Mar 2021 14:26 by Stormholt.
- Thank you received: 7488
02 Feb 2021 15:49 #197439
Replied by tommylight on topic Weird coordinate position display
Can not recall what exactly, but that has to do with localisations, so try to set locale to UTF8.
- Stormholt
03 Feb 2021 08:13 #197523
by Stormholt
Replied by Stormholt on topic Weird coordinate position display
My system locale is already set to UTF-8, or is it in linuxcnc the locale has to be set? If so, where can i do that?
03 Feb 2021 23:09 #197605
Replied by andypugh on topic Weird coordinate position display
The issue, and a possible solution, is described here:
github.com/LinuxCNC/linuxcnc/issues/659
- Stormholt
04 Feb 2021 08:10 #197623
by Stormholt
Thank you very much !
Time to create page: 0.442 seconds
