MIN_SPINDLE_OVERRIDE = 0.5 CUESTION
5 years 7 months ago #203012 by andypugh
Replied by andypugh on topic MIN_SPINDLE_OVERRIDE = 0.5 CUESTION
RobotMatic wrote: I also understand how hard it is for developers to change something that was always like this.
It isn't developer inertial in this case, it is just that you seem to be the first to have been troubled by the fact that Axis doesn't do this.
5 years 7 months ago #203072 by cakeslob
Replied by cakeslob on topic MIN_SPINDLE_OVERRIDE = 0.5 CUESTION
Hey, here, you can add this to your .axisrc or usercommand.py file
root_window.tk.call('.pane.top.spinoverride.foscale','configure','-from','50')
in the example, 50 is the min override percentage , since theres nothing for it in axis it should be safe to use
since we are on the topic, you can adjust the override increments aswell
root_window.tk.call('.pane.top.spinoverride.foscale','configure','-from','50','-resolution','10')
5 years 7 months ago #203127 by db1981
Replied by db1981 on topic MIN_SPINDLE_OVERRIDE = 0.5 CUESTION
Hello,
i had the same problem on a machine in the past,
this is the patch for this. it is not migrated to 2.8 yet, but this should be an easy task.
github.com/dbraun1981/linuxcnc_patches_2...indle_override.patch
5 years 6 months ago - 5 years 6 months ago #205207 by RobotMatic
Replied by RobotMatic on topic MIN_SPINDLE_OVERRIDE = 0.5 CUESTION
Thank you very much for all the proposed solutions !!!!
as can be proposed for this patch to be native. ?
How do you tell the development group to analyze putting it?
is it possible that the next update 2.8.2 will have it ???
Last edit: 5 years 6 months ago by RobotMatic.
5 years 6 months ago #205917 by zack
Time to create page: 0.836 seconds
