Image-to-Gcode: Roughing with different tool than Engraving possible ?
- hwe
13 Dec 2021 09:06 #229001
by hwe
Image-to-Gcode: Roughing with different tool than Engraving possible ? was created by hwe
Is it possible to split the Image-to Gcode path into a roughing and engraving job, and then using different tools for the jobs ?
For roughing I would like to use a bigger tool and for engraving a V-Cut engraver.
If image-to-gcode cannot support this, is there another tool for picture-to-gcode converison which can support this (freeware/opensource) ?
I am using linuxcnc 2.8.1.
- Thank you received: 7490
13 Dec 2021 09:34 #229006
Replied by tommylight on topic Image-to-Gcode: Roughing with different tool than Engraving possible ?
Back when i was using it, the image2gcode did not work for me, but dmap2gcode did.
It is free so give it a try.
- hwe
13 Dec 2021 17:24 #229019
by hwe
Replied by hwe on topic Image-to-Gcode: Roughing with different tool than Engraving possible ?
Thanks - I tested it and it is really simple and useful !
Separate files for roughing and engraving - very helpful !
Time to create page: 1.169 seconds
