How can I make the axis movement immediate in the remapping code?
  • chen1234
  • chen1234's Avatar Topic Author
  • Senior Member
  • Senior Member
26 Jan 2022 03:27 #233144 by chen1234
I did an io signal detection in the remapping code, it can control the Z axis movement after reading a high level signal, I use the (self.execute("G0 Z %d"%b)) function to Control the Z axis, b is my parameter, but I found in the test that self.execute will not be executed in the loop, but will be executed after the loop ends, which cannot achieve my needs. I would like to know how to control the axis to make it execute immediately? Please give me some advice.
Thanks, here is my code:
def m203(self,**words):
    #yield INTERP_EXECUTE_FINISH
    if self.task:
        a = (words['s'])
        b = a
        c = 0
        while 1:
            x = hal.get_value('lcec.0.5.RXPDO-4')
            if x == 1:
                y = hal.get_value('lcec.0.5.RXPDO-5')
                if y == 1:
                    while 1:
                        if y == 0:
                            c += 1
                            print("c = ", c)
                            if b < 44 and b >-44:
                                b += a
                                break
                elif y == 0:
                    time.sleep(0)
            elif x == 0 or hal.get_value('lcec.0.5.TXPDO-2') == 1:
                break
26 Jan 2022 06:33 #233151 by cmorley
try:
after execute statement
The following user(s) said Thank You: chen1234
  • chen1234
  • Senior Member
  • Senior Member
27 Jan 2022 02:03 - 27 Jan 2022 02:09 #233249 by chen1234
Thanks for your answer,
I solved the problem, I found that (self.execute("G0 Z %d"%b)) can't go to execute the Z axis movement immediately.
I solved the Z axis control delay using ( External Axis Offsets ) and it got my Z axis feeds working. I thought I should share the solution, below is my code and configuration.
remap.py:
    if self.task:
        a = (words['s'])
        b = a
        while 1 :
            y = hal.get_value('lcec.0.5.RXPDO-4')
            if y == 1:
                x = hal.get_value('lcec.0.5.RXPDO-5')
                if x == True:
                    while 1:
                        if x == False:
                            hal.set_p("axis.z.eoffset-counts","%d"%b)
                            print("b=",b)
                            b += a
                            break
                elif x == False:
                    time.sleep(0)
            elif y == 0 or shal.get_value('lcec.0.5.TXPDO-2') == 1:
                time.sleep(0)
                break
        hal.set_p("axis.z.eoffset-counts","0")
myaxis.ini:
[AXIS_Z]
OFFSET_AV_RATIO  =   0.2
myaxis.hal:
setp axis.z.eoffset-enable 1
setp axis.z.eoffset-scale 1
Last edit: 27 Jan 2022 02:09 by chen1234.
