Cannot start EMC with axis on a 10.04/2.4 system
03 Oct 2010 17:37 #4500 by step4linux
hello,
I have persisting problems to use EMC 2.4.4 (Ub 10.04) with axis.
Other GUIs work perfect, including mocca, as well as the stepconf wizzard.
EMC with axis crashes with seg fault, whatever config I use. Could be old proven configs (yes removed NML...) or new created by stepconf. The same configs work with tkemc, mini, mocca (not touchy).
when I start emc -d I see this:
+ axis -ini /home/gerd/emc2/configs/NewStepper/NewStepperAxis.ini
/usr/bin/emc: Zeile 654:  1216 Segmentation fault      $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
+ result=139
+ Cleanup
+ echo 'Shutting down and cleaning up EMC2...'
dmesg tells:
[  311.280644] RTAI[usi]: enabled.
[  311.744712] RTAI[math]: loaded.
[  312.545142] config string '0x378 out  '
[  318.797623] axis[1216]: segfault at 0 ip (null) sp bf95737c error 4 in libXext.so.6.4.0[110000+e000]
[  324.250886] RTAI[math]: unloaded.
Anybody has a hint how to proceed ? what to check ?
thanks for help, Gerd
07 Jul 2011 17:51 #11232 by CannonFodder
Replied by CannonFodder on topic Re:Cannot start EMC with axis on a 10.04/2.4 system
I noticed there were no replies to this post. Has anyone figured out Gerd's problem? I have the same issue with two desktops and a laptop at home using either the Live CD or full install, but the same Live CD works fine on Dell desktops and laptops at work.
Thanks,
Randy
07 Jul 2011 19:33 #11235 by cncbasher
i'm taking a stab at this , as i have had something similar , use apt-get and update or reinstall using package manager LibXext.so.6.4.0
08 Jul 2011 02:55 #11244 by CannonFodder
CNCBasher,
Thanks, that didn't help. I rerun it over and over and over. Any interface except axis works. Axis and axis based interfaces crash. I notice the segmentation fault randomly occurs in other libraries. Below is my last run attempt and below that is other segfaultt from previous runs.
Thanks,
Randy
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/cnc/emc2/configs/sim'
Machine configuration file is 'axis.ini'
INIFILE=/home/cnc/emc2/configs/sim/axis.ini
PARAMETER_FILE=sim.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Starting EMC2 TASK program: milltask
Starting EMC2 DISPLAY program: axis
Killing task emcsvr, PID=6790
Killing task milltask, PID=6840
Cleanup done
Debug file information:
/usr/bin/emc: line 654: 6841 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
6790
PID TTY STAT TIME COMMAND
6840
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 2701.182656] I-pipe: Domain RTAI registered.
[ 2701.182693] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 2701.182699] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 2701.182717] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2701.182723] PIPELINE layers:
[ 2701.182732] da619e20 9ac15d93 RTAI 200
[ 2701.182737] c085cb20 0 Linux 100
[ 2701.263519] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2701.265081] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 2701.265102] RTAI[sched]: hard timer type/freq = APIC/6264148(Hz); default timing: periodic; linear timed lists.
[ 2701.265110] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1202687000 hz.
[ 2701.265117] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 2701.270064] RTAI[usi]: enabled.
[ 2701.566727] RTAI[math]: loaded.
[ 2707.081389] axis[6841]: segfault at 0 ip (null) sp bf9b0bfc error 4 in _tkinter.so[110000+a000]
[ 2711.407587] RTAI[math]: unloaded.
[ 2711.627738] SCHED releases registered named ALIEN RTGLBH
[ 2711.644650] RTAI[malloc]: unloaded.
[ 2711.744070] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2711.760128] I-pipe: Domain RTAI unregistered.
[ 2711.760159] RTAI[hal]: unmounted.
[ 1913.792715] axis[4464]: segfault at 0 ip (null) sp bf9e06dc error 4 in libcrypto.so.0.9.8[110000+138000]
[ 1979.355086] axis[4685]: segfault at 0 ip (null) sp bfa4589c error 4 in libutil-2.11.1.so[110000+2000]
[ 2068.324668] axis[4905]: segfault at 0 ip (null) sp bfebd1cc error 4 in libz.so.1.2.3.3[110000+13000]
[ 2281.412599] axis[5724]: segfault at 0 ip (null) sp bfaf453c error 4 in libpthread-2.11.1.so[113000+15000]
08 Jul 2011 07:25 #11245 by cncbasher
this usualy happens when some librarys are updated and some dependancys are missed or lost , is this with a clean installation of the live cd , or have you updated from an older release at some stage , try update manager if you happen to have the update manager turned off .
the problem you are seeing is an interoperability between librarys or library versions , and possibly an old incompatabilty with a library recently installed
form any newly installed application , using an old library .
it may be a better solution if this persists , to backup your emc config , and do a clean install of the live cd
look in the package manager for any conflicts or multiple versions of the same library , this may point you to a solution
08 Jul 2011 11:57 #11256 by andypugh
This might point at an OpenGL issue. The other UI's don't use OpenGL (well, I am not sure about Mocca).
You could try software-only OpenGL:
wiki.linuxcnc.org/emcinfo.pl?TroubleShoo...oftware_based_OpenGL
08 Jul 2011 12:22 #11260 by CannonFodder
Get the same results from the Live CD. It functions normally on my computer at work. So, I don't think it is a library mismatch from an update.
The errors above are from my desktop computer I want to use to run the cnc table. Reinstalled on my laptop and did all the recommended updates and no longer get the segfault errors. Now it says there is a configuration error, but fails to give any clue as to what the configuration error is or which config file is having the issue.
08 Jul 2011 12:30 #11261 by CannonFodder
CNCBasher,
Andy,
Will try the software OpenGL when I get home this evening.
Thanks for all the ideas,
Randy
08 Jul 2011 23:24 #11283 by CannonFodder
Andy,
The software OpenGL drivers did it. Thanks.
Now if I can get it to run on my laptop. I'm thinking my problem is no printer port on it. Is there a way run the software with out any hardware? I want to use my laptop to develop and test the code before going out to the garage to run it.
Randy
08 Jul 2011 23:26 #11284 by andypugh
Yes, you can compile for simulator, or just use one of the sim configs with a standard install.
wiki.linuxcnc.org/emcinfo.pl?EMC2_Pure_Simulator
