How to add buttons at interface Axis?
  • Nest
  • Nest's Avatar Topic Author
  • Premium Member
  • Premium Member
17 Mar 2022 08:40 #237522 by Nest
hi, i want to add two buttons at Axis interface, i want to add the probe touch button and button go to position cero of piece. Is difficult to add that buttons?
thanks you
17 Mar 2022 09:03 #237523 by phillc54
Replied by phillc54 on topic How to add buttons at interface Axis?
There are some customization hints in the documents
linuxcnc.org/docs/2.8/html/gui/axis.html...d_a_goto_home_button
  • Nest
  • Premium Member
  • Premium Member
21 Mar 2022 19:44 #237949 by Nest
Replied by Nest on topic How to add buttons at interface Axis?
Hi, where do you add that code?
21 Mar 2022 22:53 #237972 by phillc54
From the same document:
linuxcnc.org/docs/2.8/html/gui/axis.html#_axisrc
I would recommend 12.4: USER_COMMAND_FILE
The following user(s) said Thank You: Nest
  • Nest
  • Premium Member
  • Premium Member
22 Mar 2022 08:30 #238001 by Nest
The information in this document is not clear, it is very difficult to understand.
thanks for your help
22 Mar 2022 12:30 #238007 by robertspark
Replied by robertspark on topic How to add buttons at interface Axis?
create a document and call it
usercommand.py
save it within your config file for your machine (~/linuxcnc/config/ ...... whatever your machine is called
open up your configuration ini file and under the display section add:
[DISPLAY]
USER_COMMAND_FILE = usercommand.py
open the usercommand.py file in Geany and edit it to add the following code:
def goto_home(axis):
    if s.interp_state == linuxcnc.INTERP_IDLE:
        home = inifile.find('JOINT_' + str(inifile.find('TRAJ', 'COORDINATES').upper().index(axis)), 'HOME')
        mode = s.task_mode
        if s.task_mode != linuxcnc.MODE_MDI:
            c.mode(linuxcnc.MODE_MDI)
        c.mdi('G53 G0 ' + axis + home)
# make a button to home y axis
root_window.tk.call('button','.pane.top.tabs.fmanual.homey','-text','Home Y','-command','goto_home Y','-height','2')
# place the button
root_window.tk.call('grid','.pane.top.tabs.fmanual.homey','-column','1','-row','7','-columnspan','2','-padx','4','-sticky','w')
# any function called from tcl needs to be added to TclCommands
TclCommands.goto_home = goto_home
commands = TclCommands(root_window)
as taken from here:
linuxcnc.org/docs/devel/html/gui/axis.ht...d_a_goto_home_button
you can edit this section / add more lines to get the button to do whatever you want:
Also
edit this section to give the button a custom name to your needs
if you have not done it before you will need to test it a few times, but its all part of learning.
you can add another button then the same way
The following user(s) said Thank You: andypugh, cakeslob, Nest
  • Nest
  • Premium Member
  • Premium Member
26 Mar 2022 19:14 #238417 by Nest
hello, I have already added two buttons to my AXIS
I have used the MDI format
1º I installed nativecam with this manual video
2º in the folder where the configuration of your machine is, there is a file called pyvcp-panel.xml, in that file is the spindle speed display, we add the buttons that we are going to use, for example one for home piece and test probe
<hbox>
        <relief>RAISED</relief>
        <bd>5</bd>
             <button>
                       <halpin>"zeropiece"</halpin>
                       <text>"Home Pieza"</text>
                       <font>('Fixed',11)</font>
                       <width>10</width>
             </button>
        </hbox>
        <hbox>
        <bd>5</bd>
            <button>
                      <halpin>"touchplate"</halpin>
                      <text>"Sonda Probe"</text>
                      <width>10</width>
            </button>
        </hbox>
3º in the same folder of the previous step in the .ini file of your configuration, the mine is CNC3040Z-DQ.ini we edit it, look for the [HAULI] section and add being that way
MDI_COMMAND = O <zero_piece> CALL
MDI_COMMAND = O <touch_plate> CALL
4º In the custom_postgui.hal file we add this
net remote-zero_piece halui.mdi-command-03 => pyvcp.zeropiece
net remote-sondazero halui.mdi-command-04 <= pyvcp.sondazero
if you look at halui.mdi-command-03 the 03 corresponds to the position of the command MDI_COMMAND in the file CNC3040Z-DQ.ini
start with 0, 1, 2, 3, 4 ....
When installing nativecam a folder is created where to put the custom configurations, the folder is in the path linuxcnc/configs/CNC3040Z-DQ/ncam/my-stuff/ inside that folder generate two new files, the first you call zero_piece.ngr and the second touch_plate.ngr
inside zero_piece.ngr type
O <zero_piece> sub
G90
G0 Z5   (coordenada z que queremos)
G0 X0 Y0    (coordenada X Y Z de la pieza)
O <zero_piece> endsub
M2
inside touch_plate.nrg type
O <touch_plate> sub
(*** GCode generated by NativeCAM for LinuxCNC ***)
(*.ngc files are best viewed with Syntax Highlighting)
(visit https://forum.linuxcnc.org/forum/20-g-code/30840-new-syntax-highlighting-for-gedit)
(or https://github.com/FernV/Gcode-highlight-for-Kate)
G21  (metric)
G17 G40 G49 G90 G92.1 G94 G54 G64 p0.001
#<center_drill_depth>       = -3.0
#<_pocket_expand_mode>      = 0
(optimization values)
#<_tool_eng1>               = 0.20
#<_tool_eng2>               = 0.30
#<_tool_eng3>               = 0.80
#<_feedfactor1>             = 1.60
#<_feedfactor2>             = 1.40
#<_feedfactor3>             = 1.25
#<_feedfactor4>             = 1.00
#<_feedfactor0>             = 1.00
#<_speedfactor1>            = 1.25
#<_speedfactor2>            = 1.25
#<_speedfactor3>            = 1.25
#<_speedfactor4>            = 1.00
#<_speedfactor0>            = 1.00
#<_probe_func>              = 38.4
#<_probe_feed>              = 200
#<_probe_latch>             = -1
#<_probe_latch_feed>        = 50
#<_probe_safe>              = 5.0
#<_probe_tip_dia>           = 3.0
#<_probe_tool_len_comp>     = 1
#<probe_height>             = 0
#<_tool_probe_z>            = 0.0
#<_off_rot_coord_system>    = 57
#<_mill_data_start>         = 70
#<in_polyline>              = 0
#<_has_z_axis>              = 1
#<_show_final_cuts>         = 1
#<_show_bottom_cut>         = 1
#<_spindle_all_time>        = 1
#<_spindle_speed_up_delay>  = 0.0
(end defaults)
#<_units_radius>            = 1  (for backward compatibility)
#<_units_width>             = 1  (for backward compatibility)
#<_units_cut_depth>         = 1  (for backward compatibility)
#<_tool_dynamic_dia>        = 0.0
(This is a built-in safety to help avoid gouging into your work piece)
/ o<safety_999> if [#<_show_final_cuts>]
/    o<safety_9999> repeat [1000]
/       M123
/       M0
/    o<safety_9999> endrepeat
/ o<safety_999> endif
(sub definitions)
(end sub definitions)
(begin Probe Surface)
(probe z and set author : Fernand Veilleux)
o<probe_surf_001_ena> if [1]
    o<probe> call [0] [0] [-1.000000]
    G10 L20 P#5220 Z[#<probe_height>]
    G0 Z[#<probe_height> + 55.000000]
    o<probe_surf_0010> if [1 EQ 1]
        M2
    o<probe_surf_0010> endif
o<probe_surf_001_ena> endif
(end Probe Surface)
O <thouch_plate> endsub
M2
Where did I get this code from? of nativecam, there are tutorials that teach how to handle nativecam, what I have done is generate a surface probe file and I have copied it in linuxcnc and pasted it inside touch_plate
The following user(s) said Thank You: RobC
  • Nest
  • Premium Member
  • Premium Member
26 Mar 2022 19:18 - 26 Mar 2022 19:22 #238419 by Nest
Last edit: 26 Mar 2022 19:22 by Nest.
Time to create page: 0.370 seconds
