Camera tab in Axis
- robertspark
- Thank you received: 216
22 Mar 2022 06:47 #237997
by robertspark
Replied by robertspark on topic camview
thanks I'll give it a try this evening
- robertspark
22 Mar 2022 19:51 #238029
by robertspark
well i learnt something else (works great!)
forum.linuxcnc.org/media/kunena/attachme...align-howtoembed.pdf
The following user(s) said Thank You: seuchato, phillc54
- Henk
- Thank you received: 92
25 Mar 2022 09:10 #238314
by Henk
Replied by Henk on topic Camera tab in Axis
Well, i got it working, not exactly sure why, but it works.
I changed the PC, it was way overdue anyway. Installed the buster ISO with 2.8, followed the instructions on the wiki, and got an error.
Then i installed glade the way you would if you wanted to do a glade vcp panel. and it works!
Henk
Henk
- EndCNC
- Visitor
06 Apr 2024 14:46 #297683
by EndCNC
Replied by EndCNC on topic camview
Hello,
i have some questions about the camview tab in AXIS. I added this lines in my ini.
EMBED_TAB_NAME = CAM
EMBED_TAB_COMMAND = halcmd loadusr -Wn camera qtvcp -c camera -x {XID} -o size=700,700 -o rotincr=.0 cam_align
so far so good. Unfortunately I couldn't find any documentation about the additional options.
Is there a list for this? For example, what does -Wn mean?
It's working great so far, but I have to rotate the camera and can't find the option to do so. I just copied the lines from my ini together. So I'm a total noob
- Thank you received: 2181
06 Apr 2024 15:56 #297687
Replied by cmorley on topic camview
-Wn is a halcmd switch (option) , not a qtvcp -switch.
It mean Wait for the Named component to load before continuing.
Sparse docs here:
linuxcnc.org/docs/stable/html/gui/qtvcp-...vcp:panels:cam-align
Rotating the image was just recently added to the master branch though, so unless you are using that it won't be easy to rotate the image.
Chris
Sparse docs here:
Chris
The following user(s) said Thank You: EndCNC
- EndCNC
- Visitor
06 Apr 2024 16:08 #297692
by EndCNC
- stz60
17 Apr 2024 10:24 #298427
by stz60
Replied by stz60 on topic camview
look on "Update auf 2.9.2"
schau mal auf "Update auf 2.9.2"
- timo
- Thank you received: 61
12 Feb 2025 04:22 - 12 Feb 2025 04:30 #321313
by timo
Replied by timo on topic camview
Last edit: 12 Feb 2025 04:30 by timo. Reason: deleted, formating issues (difficult)
- timo
12 Feb 2025 04:37 #321314
by timo
I first found a lot of advise to use mplayer. Could not make it do anything. (LinuxCNC 2.9.4 Debian 12 Bookworm PREEMPT-RT ISO) download from 9th Feb 2025
The qtvcp lines in the *.ini made a picture with several cameras I tried.
Time to create page: 0.154 seconds
