Axis TCL code - bugs?
4 years 6 months ago - 4 years 6 months ago #240244 by RGH
Axis TCL code - bugs? was created by RGH
Not sure if this is the right place to post this stuff.
Currently I'm doing some stuff that requires a certain understanding of the implementation of the speed sliders in AXIS.
There are two procs involved that I'm failing to make real sense of. Additionally they seem to either be buggy or the codes purpose is even more obscure than it seems.
It would be great if a dev could have a look at my annotations and check the respective comments on potential bugs.
Also I would appreciate if you could shed some light on what the purpose of the code is.
Thanks.
# purpose? # gets two numeric strings, returns an index # last return stmt out of bounds of s1 proc places {s1 s2} {     # returns index of last int digit of s1     #     when s1 > 1 (numeric gt op if s1 is numeric)     #     and integer part of s1 and s2 differ     if {$s1 > 1 && int($s1) != int($s2)} {         return [expr {[string first . $s1]-1}]     }     set l1 [string length $s1]     set l2 [string length $s2]     # iterate s1 and s2 starting at pos 15, till end of shorter string     # why start @15? -> val2vel formats with %32.5f so there's a bunch of leading spaces for {set i 15} {$i < $l1 && $i < $l2} {incr i} {         set c1 [string index $s1 $i]         set c2 [string index $s2 $i]         # return current index         # when         #     s1 @ idx isn't a 0 or decimal sep         #     s1 and s2 differ @ pos         if {$c1 != "0" && $c1 != "." && $c1 != $c2} { return $i }     }     # just return the len of s1     # all other return values are related to 0-based positions     # is this intentional or -1 is missing?     return [string length $s1] } # purpose? # translates slider val to speed value # but wiggles the slider val slightly left and right and # decides what value to return based on 'places' # bugged, last_... never set / prev_... set but not used proc val2vel_show {val maxvel} {     # translate slider value [.0, 1.] to speed value     set this_vel [val2vel $val $maxvel]              # prep some vars     set next_places 0     set last_places 0          # get speed value and 'places(current vel, offseted vel)' when offsetting slider by 0.005     #     to the left if possible -> next_...     #     to the right if possible -> prev_...     if {$val > .005} {         set next_vel [val2vel [expr {$val - .005}] $maxvel]         set next_places [places $this_vel $next_vel]     }     if {$val < .995} {         # this should be last_... there is no prev_...         set prev_vel [val2vel [expr {$val + .005}] $maxvel]         set prev_places [places $this_vel $prev_vel]     }     # compare 'places' and return adjusted string     # last_places still is 0     if {$next_places > $last_places} {         string trim [string range $this_vel 0 $next_places]     } {         string trim [string range $this_vel 0 $last_places]     } }
Last edit: 4 years 6 months ago by RGH. Reason: added to comments
4 years 6 months ago #240272 by andypugh
Replied by andypugh on topic Axis TCL code - bugs?
I can't really read Tcl. But what wrong behaviour are you seeing?
4 years 6 months ago #240278 by RGH
Replied by RGH on topic Axis TCL code - bugs?
It's not that I'm observing wrong behavior. I'm reading the code figuring out how certain parts work and these two procs are really resisting and have some odd lines that might not be intended.
4 years 6 months ago #240704 by andypugh
I asked the author:
"The function's concerned with showing a value on one of the "per second" sliders in a way that doesn't show an excess of digits. The sliders operate sort of exponentially. What's desired is that if the slider actually MOVES by a position that the numeric value displayed changes too. The general idea is that it finds some "nearby" slider values and converts them to velocities; both numbers are formatted the same way (%32.5) and then the first non-common digit is found.
no idea if there are bugs or not, but there are always bugs so I'll guess 'yes'."
The following user(s) said Thank You: RGH
4 years 6 months ago #240733 by RGH
Thank you!
Knowing the intention helps a lot.
Did you pass the snippet with my comments along? I think the issues I found still apply (at least messed up variable names in val2vel_show).
In any case I will check again now knowing what the two functions are supposed to do and post a potential fix in the hope that it is considered.
Btw. what I'm working on is related to changing the jog speed externally via axisui.xxx pins and having the ui (slider/text box) reflect the change without influencing it.
4 years 6 months ago #240815 by andypugh
I didn't, though I did provide a link to the forum post.
Time to create page: 0.056 seconds
