Andy, please advise - what's the proper way to address this stuff?
I doesn't seem to make much sense to post more details and eventual fixes here in the forum and you playing the messenger or me hoping the author joins the discussion.
Should I raise an issue on github? Will that get the attention from the person responsible?
You can try raising an issue, but as there is no apparent problem being caused, it might not get much attention.
If you are in a position to create a pull-request that fixes possible issues and/or adds a new feature (ie remote slider control) then that is more likely to get attention.
(But even then, patience is likley to be needed, I am months behind in looking at pull requests)
The problems are partly cosmetic and partly not evident unless one pays close attention to how the sliders react and the associated numeric labels behave. Basically the functionality the author described is broken. But it has little impact on usability and as is more of an annoyance. I guess I wouldn't have noticed if I wasn't working on those additional axisui hal pins to control jog speed.
Currently I don't have a suitable dev setup. I have made the fixes in situ on a regular installation. So a patch file is the only thing I would have at hand.
Anyway... thank you - I will think about how to proceed based on your infos.
