Reset machine coordinates on special machine.
4 years 3 months ago - 4 years 3 months ago #246623 by cakeslob
I think it must be an axis because it needs trajectory planning between x y z and a.
Keeping this in mind
I dont know how the lengths are sent to the machine or how the programs look, but the machine feeds pizza in one direction (x), of variable lenghts, from a giant 1km long spool of pizza, and then a axis pizza cutter cuts it. With a 1 pizza per minute cycle time, and several other servos that I will assume are for things like cheese control, sauce spreading and anchovy distribution, but you have these axis under control.
Does the 1km pizza spool need to be X axis?
Could it be like an external stepgen in hal (synced with tc comp?) with a remapped letter code like E and commanded incrementally? Or something in classic ladder?
If you only need it to feed an variable incremental amount of pizza every cycle, does that feed roller need to be X axis or can it be something else, like how paste extruders, or 3d printers, or like a bar stock cnc lathe?
Last edit: 4 years 3 months ago by cakeslob.
4 years 3 months ago #246735 by BigGray
The Pizza cutter cuts shapes in the "pizza", like a star for example.
The A axis calculates the amount of turns of the cutter wheel needs to make it travels from current to commanded position.
An extruder is similar, I just don't need to store the amount of turns the cutter made as it needs to be reset for the following piece.
4 years 3 months ago #246751 by BigGray
Thanks Andy I had a quick look at it.
Did not see a function which would do what I wanted.
CANON_POSITION GET_EXTERNAL_POSITION just finds the current positon.
Looking trough the code, homing.c has the homing functions.
HOME_SET_SWITCH_POSITION sets the joint offset on the final move.
joint->pos_cmd+=offset;
joint->pos_fb+=offset;
joint->free_tp.curr_pos+=offset;
joint->motor_offset-=offset;
Those are defined in motion.h
double pos_cmd //commanded joint position
double pos_fb //position feedback ; comp removed
double motor_offset /* diff between internal and motor pos, used to set position to zero during homing*/
I suspect I cannot access those variables while running gcode;
In EMC_NML.hh I found;
EmcPose postion //current commanded position
EmcPose actualPostion //current actual postion ; from forward kins
Trajectory planner (tp.c) has tp-> currentPos
hmm maybe i could reset A in
int tpCompleteSegment(....) //cleanup after a trajectory segment is complete
Looking at it trajectory planner tp-> currentPos looks like the right var to reset for A
could hardcode that.
X needs to be reset at every cutoff, seems a bit weird to have to access trajectory planner for that.
Or am I completely wrong and is the current positon not in tp->currentPos?
Well yea seems to be in motion.h
emcmot_internal_t struct has a member called coord_tp which contains currentPos.
Can I just update currentPos like that or will that result in something weird?
4 years 3 months ago #246757 by chris@cnc
Did we have the G91 option? It's possible to use program in incremental mode?
Another idea is to use external encoder and the "encoder.N.reset bit".
I think two simple sensors count and one proxy reset.
linuxcnc.org/docs/stable/html/man/man9/encoder.9.html
The following user(s) said Thank You: BigGray
4 years 3 months ago #246946 by BigGray
G91 would make programming too difficult.
encoder.N.reset bit indeed works, also works while running g-code.
Unfortunately it causes a following error which disables the drives.
If i reenable the drives the reset indeed has completed.
I tried disabling the pid loop but still got the following error.
using hal configuration both pos_cmd and pos_fb are reset to zero as well.
Any ideas how to fix the following error?
4 years 3 months ago #247329 by andypugh
Can you explain why having very large numbers in the machine absolute coordinates is a problem?
If you display the working coordinates you won't see them.
