Help: Creating a button in Axis GUI for loading a specific G-Code file.
- Aravind
- Thank you received: 3
04 Mar 2024 10:05 #295120
by Aravind
Help: Creating a button in Axis GUI for loading a specific G-Code file. was created by Aravind
ISSUE: Help for creating a button in axis gui for loading a specific G-Code file
I am trying to add a custom button in linuxcnc axis gui for loading a particular G-Code file. Well I need to operate this button using classicladder plc where this button will get activated when certain physical buttons are turned on.
I could add a custom button in axis gui after referring the section "13.12. Add Button to manual frame" in the AXIS GUI document : linuxcnc.org/docs/2.8/html/gui/axis.html...d_a_goto_home_button
But I couldn't find how to use that button to load a particular g-code file.
And I am not able to locate that button address in hal configuration window for netting with classicladder pins.
Kindly help me to deal with this.
Hope to get response.
-Aravind
-Aravind
- Thank you received: 2163
04 Mar 2024 13:34 #295134
Replied by Aciera on topic Help: Creating a button in Axis GUI for loading a specific G-Code file.
Yes
1. add this to the [RS274NGC] section of your ini file2. add this to the [HALUI] section of your ini file3. create a folder 'mcodes' in your config folder and create a file 'M127' in this folder.
4. mark the file 'M127' as executable
5. copy this into the file 'M127' and save:Note: this is the path/file you would need to adjust to load your specific file, here we load '3D_Chips.ngc' as an example '/home/user/linuxcnc/configs/sim/axis/nc_files/3D_Chips.ngc'
Also note that the '&' at the end is important, as otherwise the load command is blocked because the 'M127' command is still running.
You can now connect the MDI-command to your GUI button in the postgui hal file.
USER_M_PATH = ./mcodesMDI_COMMAND = M1274. mark the file 'M127' as executable
#!/bin/bash
axis-remote /home/user/linuxcnc/configs/sim/axis/nc_files/3D_Chips.ngc &Also note that the '&' at the end is important, as otherwise the load command is blocked because the 'M127' command is still running.
The following user(s) said Thank You: meister, besriworld, Unlogic, Aravind, Ehsan_R
- Thank you received: 4648
05 Mar 2024 12:29 #295224
Replied by andypugh on topic Help: Creating a button in Axis GUI for loading a specific G-Code file.
You can _probably_ do this in fewer steps using a GladeVCP or QtVCP panel, as they support Python handler files which could directly interface with axis remote (or use the Python interface)
These would probably be more actual work, and more code to write, but would involve fewer steps in the command chain.
The following user(s) said Thank You: Aravind
- cakeslob
- Thank you received: 280
05 Mar 2024 15:16 #295235
by cakeslob
Replied by cakeslob on topic Help: Creating a button in Axis GUI for loading a specific G-Code file.
Do the thing the other guys suggested, but in plasmac2 (and cakeslobs "regularmac800") we have a button panel where you can add button that loads a gcode/python/bash/ file. I havent played with it at all yet, but i think the python code for the usercommand file is something like this
github.com/cakeslob/regularmac_800/blob/...gularmac_800.py#L945
linuxcnc.org/docs/2.8/html/plasma/plasma...#custom-user-buttons
commands.open_file_name(code['file'])github.com/cakeslob/regularmac_800/blob/...gularmac_800.py#L945
- phillc54
- Thank you received: 2100
06 Mar 2024 03:42 - 06 Mar 2024 04:07 #295284
by phillc54
Replied by phillc54 on topic Help: Creating a button in Axis GUI for loading a specific G-Code file.
A quick and dirty way is to have a user_command file with something along the lines of:
linuxcnc.org/docs/2.8/html/gui/axis.html#_user_command_file
Edit: Oops, I missed the bit about activating it from a hal pin...
This adds a hal pin named axis.loader to load the file:
root_window.tk.eval('button .pane.top.tabs.fmanual.mybutton -text {Open\nMy File} -command {open_file_name /home/phill/linuxcnc/nc_files/3D_Chips.ngc} -height 2')
root_window.tk.eval('grid .pane.top.tabs.fmanual.mybutton -column 1 -row 6 -columnspan 2 -padx 4 -sticky w')linuxcnc.org/docs/2.8/html/gui/axis.html#_user_command_file
loader = False
myFile = '/home/phill/linuxcnc/nc_files/3D_Chips.ngc'
myButton = 'Open\nMy File'
root_window.tk.eval(f'button .pane.top.tabs.fmanual.mybutton -text {{{myButton}}} -command {{open_file_name {myFile}}} -height 2')
def user_hal_pins():
comp.newpin('loader', hal.HAL_BIT, hal.HAL_IN)
def user_live_update():
global loader
if loader != comp['loader']:
loader = comp['loader']
if loader:
commands.open_file_name(myFile)
Last edit: 06 Mar 2024 04:07 by phillc54.
- Ehsan_R
15 May 2024 07:13 #300661
by Ehsan_R
Replied by Ehsan_R on topic Help: Creating a button in Axis GUI for loading a specific G-Code file.
If we want to do this with an input pin, what should we do?
15 May 2024 08:54 #300663
This explains how to call and MDI command from HAL pin:
forum.linuxcnc.org/38-general-linuxcnc-q...parallel-port#292850
Time to create page: 0.225 seconds
