cutter compensation or wear compensation for dummies?
14 Mar 2024 20:12 #295917 by JimS
Wanting to use compensation to make small corrections to adjust for cutter diameter to get more accurate feature sizes.  Is this something that can be entered using Axis UI or does this require gcode editing?  Having a hard time finding simple examples.  For example, if I mill a 1/2" hole with a 1/4" end mill and the hole ends up being 0.4990" I want to enter offset adjustment of 0.005 (radius error) without rerunning post in CAM package (Fusion 360).
14 Mar 2024 22:06 #295920 by rodw
From memory, you have 2 methods from F360
1. adjust the tool diameter in the F360 tool library
2. Subject to a setting change in F360, the diameter in the linuxcnc tool library can be used to set the tool wear offset.
Please read the F360 docs as it is described
15 Mar 2024 02:25 #295932 by JimS
I said for dummies but I figured that much out. I am hoping for more than RTFM...
15 Mar 2024 02:59 #295933 by MaHa
Unless G41 / G42 is used in Gcode, you can modify parts by cutter compensation. Normally from CAM, toolpath is created with toolcenterpoint with offset from selected tool. You will be bound to another pp run for changes, as you don't like. For this purpose, i create a few similar jobs, each increasing measure compensation by a small value, eg. 0.02mm. When the expected result achieved, abort. Without G41G42 active, modification from cam is the only way.
15 Mar 2024 05:45 #295936 by rodw
I'm sorry but I gave you the info I have. I am not going to RTFM so I can answer a question I would have to research.
Instead of being arrogant and impatient, be patient and somebody might add more detail on the question.
The following user(s) said Thank You: Cant do this anymore bye all
  • Platinum Member
  • Platinum Member
15 Mar 2024 06:43 #295937 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic cutter compensation or wear compensation for dummies?
To be perfectly honest assuming the cutter is not of the correct diameter may not be the issue, other factors that can play part (they can accumulate), overall machine accuracy, rigidness of machine, squareness of machine, tool deflection, any backlash, speeds & feeds, cooling & chip evacuation. Messing up decimal points wont help either.
This was an interesting article & video on various methods of "making holes".
tarkka.co/2021/02/07/holier-than-thou/
