discrepancy between commanded and actual on z-axis
- taras
11 Nov 2010 08:33 #5211
by taras
discrepancy between commanded and actual on z-axis was created by taras
I press 'esc' when M0 is the current command. Then I load next .ngc program wich consist of commands for tool length probing (G38.2, G43.1 Z[#5063-#1000] etc.), and the commands to cut the material (g1,g0, etc.). When was processed command g0 z20 (after tool probing and applying of G43.1 Z), z-axis go down to 2.4564 value (the same value was on the screen of AXIS gui), after that any attempts to handle the z-axis were unsuccessful. (z-axis was placed in the wrong values different from commanded) Problem has been resolved when the EMC restarted.
EMC v 2.4.5
Ubuntu hadry heron 8.04 (was installed from EMC 2.3.0 installation disk)
Excuse me for bad English.
EMC v 2.4.5
- BigJohnT
- Thank you received: 1176
11 Nov 2010 13:01 - 11 Nov 2010 13:06 #5229
by BigJohnT
Replied by BigJohnT on topic Re:discrepancy between commanded and actual on z-axis
I does sound like you might have had an offset in your current coordinate system as well. To be sure before you touch off switch to a coordinate system you don't use like G59.3, touch off then switch back to your normal coordinate system.
If that is not the problem you might attach the g code file...
Last edit: 11 Nov 2010 13:06 by BigJohnT.
- Thank you received: 4995
11 Nov 2010 13:07 #5231
Replied by andypugh on topic Re:discrepancy between commanded and actual on z-axis
Is is possible that the GUI was set to display machine coordinates rather than relative coordinates? (press # to cycle between them)
- taras
11 Nov 2010 13:32 #5233
by taras
Replied by taras on topic Re:discrepancy between commanded and actual on z-axis
But, regardless of active offsets (g54, ...) and offset by Z, when I type g0z20 , digits on screen in gui should be established to "z +20.0000"?
2 andypugh:
During this error, I was in relative coordinates mode.
Thanks.
2 andypugh:
Thanks.
11 Nov 2010 20:37 #5252
taras wrote:
Yes, as far as I know that is the case. I would have to experiment to be sure that it was the case with radius compensation, but I believe it is.
Is the problem repeatable? A screenshot might contain some information that helps?
During this error, I was in relative coordinates mode..
- taras
11 Nov 2010 21:07 #5255
by taras
No, not very repeatable. It appears rarely, but this is enough to spoil the work. Tomorrow I'll try deliberately call an erroneous situation and will make a screen shot and maybe a photo.
- BigJohnT
11 Nov 2010 21:24 #5256
by BigJohnT
Before you start the move does the Z DRO read 0.0000?
Are you watching commanded position or actual position?
Make sure you can recall the steps to reproduce the error.
Time to create page: 0.060 seconds
