When trying to edit G-code file nothing happens
- kmeld
- Thank you received: 4
14 Jun 2024 05:48 #302995
by kmeld
When trying to edit G-code file nothing happens was created by kmeld
I have a problem with launching edit G-code file from Axis file menu.
Normally, as far as I recall, when I had a G-code file opened in Axis and than I had go file->edit text editor was automatically launched and current file opened.
now when I do that nothing happens. editor is not launched.
How do I solve this problem?
Cris.
Cris.
- Thank you received: 2177
14 Jun 2024 05:54 #302996
Replied by Aciera on topic When trying to edit G-code file nothing happens
Check the entry for EDITOR in the [DISPLAY] section of your .ini file (eg EDITOR = gedit) and make sure that entry (eg gedit) actually opens a text editor when used in a terminal.
- kmeld
14 Jun 2024 06:13 #302998
by kmeld
Replied by kmeld on topic When trying to edit G-code file nothing happens
It seems that I do not have gedit installed.
what will be most convenient editor for G-code on Linux?
how do I install it?
Cris.
Cris.
- Thank you received: 7505
14 Jun 2024 06:33 #303002
Replied by tommylight on topic When trying to edit G-code file nothing happens
For the official ISO, editor should be mousepad, for Mint with Mate DE it should be xed, etc.
- B.Reilly01
- Thank you received: 24
30 Jun 2024 10:56 #304090
by B.Reilly01
Replied by B.Reilly01 on topic When trying to edit G-code file nothing happens
You could just install gedit... no idea if it's a good editor or not, but it is an editor.
sudo apt install gedit
Time to create page: 1.070 seconds
