G54 ON START UP
- COFHAL
- Thank you received: 62
27 Jun 2024 01:11 #303862
by COFHAL
G54 ON START UP was created by COFHAL
I don't understand why the GUI axis always starts in G53 and not in G54, it only changes to G54 when one of the axes is set to zero. That only happens to me with a special configuration. I have compared the INI file with others and find no differences. I honestly can't find a way to solve it.
- B.Reilly01
- Thank you received: 24
27 Jun 2024 12:57 - 27 Jun 2024 12:58 #303895
by B.Reilly01
Replied by B.Reilly01 on topic G54 ON START UP
Do you have G54 in the startup G-Code in the INI file? I also suspect since it's not zero'd yet, the machine is in G53 until it finds home - it doesn't actually know where it is for certain, so G54 isn't relevent yet. I may be reading your post incorrectly... Could you post your HAL and INI files? G54 goes here:
[RS274NGC]
RS274NGC_STARTUP_CODE = F10 S300 G20 G17 G40 G49 G54 G64 P0.001 G80 G90 G91.1 G92.1 G94 G97 G98
Last edit: 27 Jun 2024 12:58 by B.Reilly01.
- COFHAL
27 Jun 2024 19:32 #303926
by COFHAL
Replied by COFHAL on topic G54 ON START UP
I already found the problem after two days, it was in the .HAL file in the various signal section, they had included the instruction halui.abort, but the truth is I don't know why this instruction changes from G54 to G53.
- COFHAL
28 Jun 2024 00:48 #303945
by COFHAL
I think the problem is really because of the number of halui instructions within the file. hal, as soon as I add an additional instruction of type halui, G53 appears at the beginning. I don't understand why that happens.
Time to create page: 0.180 seconds
