Subrouting Path - no effect
- kmeld
- Thank you received: 4
24 Jul 2024 19:28 #305973
by kmeld
Subrouting Path - no effect was created by kmeld
I have added
SUBROUTINE_PATH = /home/km/G_Code/SUB/
in to DISPLAY sectoion of INI file, but this has no effect.
I can only call subroutines if their files are in PROGRAM_PREFIX directory.
How to correctly specify subroutine patch for AXIS?
Cris.
I have added
Cris.
- Thank you received: 7496
25 Jul 2024 00:44 #305982
Replied by tommylight on topic Subrouting Path - no effect
Fixed the tittle, it was "patch", threw me off.
Not sure, but i think subroutines should be set executable in permissions.
- MaHa
- Thank you received: 241
25 Jul 2024 00:56 #305984
by MaHa
Replied by MaHa on topic Subrouting Path - no effect
I can tell only from my experience, i set SUBROUTINE_PATH and USER_M_PATH in [RS274NGC] section.
- Thank you received: 2177
25 Jul 2024 11:30 #306007
Replied by Aciera on topic Subrouting Path - no effect
In the [DISPLAY] section you need use 'PROGRAM_PREFIX':
linuxcnc.org/docs/html/config/ini-config...#sub:ini:sec:display
PROGRAM_PREFIX = ~/linuxcnc/nc_files - The default directory for G-code files, named subroutines, and user-defined M-codes. The PROGRAM_PREFIX directory is searched before the directories listed in [RS274]SUBROUTINE_PATH and [RS274]USER_M_PATH. Please Log in or Create an account to join the conversation.
- kmeld
28 Jul 2024 16:56 #306246
by kmeld
Replied by kmeld on topic Subrouting Path - no effect
Ok, I do not know what exactly solved the problem but I have it working now.
I have changes SUB path not to be sub-directory of main program folder
I have set up SUB path in DISPLAY and in RS274NGC sections of INI file.
Now subroutines are properly read from intended directory.
Cris
Cris
Time to create page: 0.124 seconds
