Tool marker disappears when using negative diameter.
- matasbuk
- Thank you received: 3
10 Oct 2024 18:09 #311757
by matasbuk
Tool marker disappears when using negative diameter. was created by matasbuk
Hello, I am using a G42 with a negative tool diameter for tool wear compensation. The problem that occurs, is when the entered tool diameter is negative, the tool marker on the gcode viewer disappears making it hard to keep progress of the cut. Is there an option for it to nor reference the diameter and leave use the stock pointer?
- Thank you received: 1482
10 Oct 2024 20:01 #311768
Replied by Todd Zuercher on topic Tool marker disappears when using negative diameter.
Why not just use G41 instead of a negative number?
The following user(s) said Thank You: matasbuk
- matasbuk
11 Oct 2024 08:22 #311798
by matasbuk
Replied by matasbuk on topic Tool marker disappears when using negative diameter.
Never thought about it this way. Might need to try out if no other option is available. Thank you!
- matasbuk
11 Oct 2024 19:39 #311831
by matasbuk
Ok, I tried it out. It works, but then using very small offsets like 0.25mm it is still hard to see compared to the original marker.
Time to create page: 0.567 seconds
