Custom Panel
1 year 7 months ago #323486 by cmorley
Replied by cmorley on topic Custom Panel
You don't replace the original ui file, though that will work.
you put it in YOUR CONFIGURATION FOLDER/qtvcp/screens/qtaxis/qtaxis.ui
Qtvcp will see it there and use it instead of the original/
The following user(s) said Thank You: noqui
1 year 7 months ago - 1 year 7 months ago #323489 by noqui
Replied by noqui on topic Custom Panel
Sorry, yes, I replaced the qtaxis.ui in my configuration folder/qtvcp/screens/qtaxis.ui (new), and then what must I do?.
Thanks a lot, cmorley
Last edit: 1 year 7 months ago by noqui.
1 year 7 months ago #323533 by cmorley
Then start linuxcnc with your selected configuration.
It should see your modified .ui file and use it.
If it does not, change the INI to debug mode (DISPLAY = qtvcp -d qtaxis)
run linuxcnc in a terminal and post the output.
Time to create page: 0.105 seconds
