Accessing "Axis"
- Calvino
25 Nov 2010 06:20 #5599
by Calvino
Accessing "Axis" was created by Calvino
I got a Sherline CNC mill with the software yesterday and I saw that the AXIS software can do the image g-code plotting (
) BUT I can't seem to find where on earth it is located. Its slightly unclear where to get it from. Anyone know how to help, the software came loaded on the machine so it sounds like its somewhere in there.
Thanks! Calvin
Thanks! Calvin
- Rick G
- Thank you received: 155
25 Nov 2010 11:28 #5601
by Rick G
Replied by Rick G on topic Re:Accessing "Axis"
Hello,
Just start emc then go to FILE then OPEN then select the file you want to filter such as a .jpg
Rick G
Rick G
- Thank you received: 4994
25 Nov 2010 12:44 #5603
Replied by andypugh on topic Re:Accessing "Axis"
It sounds like perhaps your system comes with one of the other GUIs active?
look in your home folder for /emc/configs/ and then try to work out which config you are using. In that folder there will be an file with a .ini extension.
Near the top of the ini file is the [DISPLAY] section and that will contain an entry DISPLAY=
Make that say DISPLAY=axis and you should start using the Axis gui.
(I realise that this might well be the answer to a completely different question to the one you are asking)
- Calvino
25 Nov 2010 18:21 #5613
by Calvino
Replied by Calvino on topic Re:Accessing "Axis"
It may, ill try both methods, thanks
Not to bash any sites but most don't really explain "how to get to it" so it should be figured out soon.
- Calvino
25 Nov 2010 18:56 #5615
by Calvino
Ok turns out the issue was on my end. I found a sheet of paper that said how to get into AXIS and i was using the wrong directory to find it
Issues solved
Time to create page: 0.062 seconds
