Clocking the Actual Machining duaration
- KenC
25 Nov 2010 12:01 #5602
by KenC
Clocking the Actual Machining duaration was created by KenC
I totally useless when it comes to programming.
Can someone kindly point me the direction to set up a clock in AXIS to clock the actual machining time? i.e. start ticxking when the "play" button is pressed & stops when the g-code ends?
Thanks in advance.
Ken
Thanks in advance.
Ken
- Thank you received: 4994
25 Nov 2010 12:45 #5604
Replied by andypugh on topic Re:Clocking the Actual Machining duaration
- BigJohnT
- Thank you received: 1176
25 Nov 2010 14:11 #5606
by BigJohnT
Replied by BigJohnT on topic Re:Clocking the Actual Machining duaration
EMC 2.5 (development version) has a new component time that is designed just for a cycle timer... and outputs the time in hours, minutes, and seconds.
www.linuxcnc.org/docview/devel/html//man/man9/time.9.html
25 Nov 2010 15:54 #5608
BigJohnT wrote:
Hmm, I wonder if it is worth putting the 1hz siggen and reset inside the component?
- BigJohnT
25 Nov 2010 16:01 #5609
by BigJohnT
That would simplify the use of it greatly IMHO. I didn't even think about an external reset... Can I just cut and paste some code from siggen or something like that?
25 Nov 2010 16:59 #5611
Comp functions get passed the time in nS since they last ran in
The "period" variable, so I think you could just add that to an internal variable. Reset would just be a case of checking
If (reset && !old_reset) time_accumulator = 0;
- BigJohnT
26 Nov 2010 13:30 #5629
by BigJohnT
I'm still trying to sort out how one would do this with the period info... If I summed up each period the number would grow pretty quick...
26 Nov 2010 13:43 #5630
I think you need to sum them up, as otherwise you will get rounding errors.
Stored in a static long long (64 bits) you would wrap round in 14,000 years. That should be long enough
Alternatively the comp code can access the rtapi_get_time and rtapi_get_clocks functions, but as these also use long longs there is not much to be gained.
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...282c53f877fc;hb=HEAD
(lines 300 onwards)
(lines 300 onwards)
- BigJohnT
26 Nov 2010 17:17 #5640
by BigJohnT
I'm having so much fun and must have eaten too much turkey yesterday as I forgot to addf the time to my servo period and was wondering why it always showed up as 0...
26 Nov 2010 17:25 #5642
BTDTGTTS
