Machine stopped in middle of program.
07 May 2025 18:58 #327967 by fc60
Greetings,
I was machining two parts that I have run before at least 30 times.
First part machined as expected.
The second part got 3/4 through the program and the spindle and axis motors stopped.
Also, the AXIS screen was frozen up. No response to keyboard nor mouse.
I turned off the power and rebooted.
Next I started LinuxCNC 2.5.5. All went well.
Reloaded the program, dialed the part back in, and reset Z zero of the cutting tool.
Pressed Cycle Start and the program ran fine.
So, what happened?
Is there an error log/file I can look through to determine the cause of the shut down?
More clues.....
LinuxCNC 2.5.5
Smithy 1240 Milling machine
Cheers,
Dave
07 May 2025 19:26 #327968 by tommylight
Replied by tommylight on topic Machine stopped in middle of program.
-power brownout
-lighting strike even several miles away
-processor had a hiccup
-failing power supply
-failing memory or memory controller
-failing capacitors on PC
etc
If any of the last 4, the issue will occur more often with time.
If the second, not much you can do.
If the first thing, and if this is a parallel port setup, and this happens again, see what equipment did you turn on in the house/shop/neighborhood, as big power draw equipment can cause this, easily, and they do for sure cause power brownouts.
08 May 2025 11:02 #328011 by fc60
Replied by fc60 on topic Machine stopped in middle of program.
@tommylight,
So, there would not be an error file/log generated I could look for?
Cheers,
Dave
08 May 2025 15:50 #328029 by tommylight
You could try sifting through
sudo dmesg
But be ready to get shocked by the amount of info there.
The following user(s) said Thank You: fc60
Time to create page: 0.250 seconds
