Axis view options are not persistant between sessions. Any thoughts?
1 year 4 months ago #330847 by chrisfischer
Awe man I got excited it would be that easy. Alas, no change.
Thanks for the idea!
1 year 4 months ago - 1 year 4 months ago #330855 by Aciera
I'm not aware of  a 'UNITS' or 'DEFAULT_UNITS' key:
linuxcnc.org/docs/stable/html/config/ini-config.html
same for 'GEOMETRY_UNITS'
[edit]
But I guess those lines come from this:
chatted with chatgpt for a few hours
Last edit: 1 year 4 months ago by Aciera.
1 year 4 months ago #330927 by JT
When I open the axis sim the units are inch, when I open the axis_mm sim the units are mm.
In the [TRAJ] section of axis the LINEAR_UNITS are inch and in the axis_mm the LINEAR_UNITS are mm.
JT
1 year 4 months ago #330944 by cakeslob
yeah that should be the only option he needs in the INI file, the one in [TRAJ] LINEAR UNITS
the ai shit up your ini file. you need to fix these sections. I dont know what angular inch U axis is or a linear spindle.
#****************************************** #*** AXIS_U ******************************* [AXIS_U] UNITS = INCH MAX_VELOCITY = 7 MAX_ACCELERATION = 20 MIN_LIMIT = -500 MAX_LIMIT = 500.0 [JOINT_3] TYPE = ANGULAR UNITS = INCH HOME = 0.0 MIN_LIMIT = -500 MAX_LIMIT = 500.0 MAX_VELOCITY = 7 MAX_ACCELERATION = 20 FERROR = 1000 MIN_FERROR = 1000 HOME_ABSOLUTE_ENCODER = 1 #****************************************** #*** SPINDLE ******************************* [AXIS_B] MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 MIN_LIMIT = -200.0 MAX_LIMIT = 200.0 [JOINT_4] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -200.0 MAX_LIMIT = 200.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 FERROR = 1000 MIN_FERROR = 1000 HOME_ABSOLUTE_ENCODER = 1
1 year 2 months ago - 1 year 2 months ago #334095 by RayJr
In my experience, I have found that changes you make in the GUI will not be saved if you do not use the file/quit to exit. I know for sure the the machine position is not saved.
Ray
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
Last edit: 1 year 2 months ago by RayJr.
Time to create page: 0.052 seconds
