Touch off, OK button greyed out
1 year 1 month ago #335059 by andypugh
The Axis touch-off allows for any valid G-code expression, including the use of parameters. (So you should be able to type [#<_x> / 2] for example, to save typing the current X position)
Given this, "bad number format" is not a bug, but "file not found" is.
github.com/LinuxCNC/linuxcnc/issues/3563
The following user(s) said Thank You: MaHa, unknown
1 year 1 month ago #335253 by RayJr
What is the best way to move from 2.9.5 back to 2.9.4?
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
1 year 1 month ago #335258 by unknown
Uninstall 2.9.5
Manually download the 2.9.4 deb files using gdebi.
1 year 1 month ago #335259 by unknown
Or you can follow the instructions here:
gist.github.com/cgomesu/70b41cfde804d4a2981029f9f71f8908
Do I need to say use Linuxcnc as your package ;)
1 year 1 month ago #335267 by juergen-home
What I did: In xfce you can go System|Synaptic Package Manager, search for Linuxcnc, mark linuxcnc-uspace. In Menu -> Package Force Version->you can select an older version -> apply.
The following user(s) said Thank You: unknown
1 year 1 month ago #335269 by unknown
Good advice, I tend to forget there's a GUI for stuff like that.
Time to create page: 0.230 seconds
