LinuxCNC homing twice in Axis SImulation
11 months 1 week ago #339156 by kwanlokto
I'm having trouble understanding why my "axis" simulation is getting "Cannot home while shared home switch is closed". This happens once I click "Home All" twice. I'm wondering if I have something setup incorrectly.
My end goal is to be able to do this via python. I have attached my current python code (which I don't think is the issue) and I get the same issue.
11 months 1 week ago #339158 by tommylight
Simulated switches so you have to move all axis to be able to home again.
11 months 1 week ago #339159 by kwanlokto
Thanks for your reply tommylight. Sorry if this sounds stupid but I selected each axis (X, Y, Z) and click the +/- buttons to move it in that direction, but it still doesn't seem like Home All works. It only seems to home the y axis (so j = 1).
Im still getting errors for j = 0 and j = 2
11 months 1 week ago #339165 by tommylight
I do recall getting the same thing sometimes, but i never really bothered with why it happens, it is a sim and i use it only to check the gcode sometimes, not for anything important.
If you want to test on a real machine but with no machine attached, use the parallel port configs, so will work even with no parallel port, but it is a real machine so nothing is simulated. You will have to use immediate homing for it though.
The following user(s) said Thank You: kwanlokto
11 months 1 week ago #339185 by rodw
I think what you experienced is expected behaviour. Once an axis is homed, it can't be homed again unless its unhomed. I did notice recently in a axis sim that the unhomed menu was not enabled...
Time to create page: 0.226 seconds
