Can't issue MDI command when not homed
- clayton2ndtry
- Thank you received: 5
29 Jan 2026 11:36 #342161
by clayton2ndtry
Can't issue MDI command when not homed was created by clayton2ndtry
But I have homed the axis and the little diamond, or whatever it is, is showing next to it. But Touch Off gives this error message. I have been using this INI file for months without problems. This is a Sherline mill so there are no limit switches. The only axis that homes is A, which is not connected. It homes and sets to 0.000.
- Thank you received: 7504
29 Jan 2026 16:39 #342180
Replied by tommylight on topic Can't issue MDI command when not homed
Machine must have all axis/joints homed before issuing MDI commands or running in Auto mode.
Or to put it your way, all axis must have the little diamond in front on DRO
- clayton2ndtry
29 Jan 2026 17:36 - 29 Jan 2026 18:05 #342182
by clayton2ndtry
Replied by clayton2ndtry on topic Can't issue MDI command when not homed
Boy that was easy. I guess I never tried this before without homing every axis. Thank you!
Last edit: 29 Jan 2026 18:05 by clayton2ndtry.
Time to create page: 0.281 seconds
