Need help about EMC2 error (HAL)
- dubostjp
10 Feb 2011 22:31 #7118
by dubostjp
Need help about EMC2 error (HAL) was created by dubostjp
Hi all,
I got an error whith the EMC2 tools. I wrote a small code to test
the HAL loadusr environment. My goal is to get the M67 command pass some
value into the zzlaser code.
When I run the following code into a halrun command started from a
bash shelf, this code is working OK.
halrun cmd ********************************************************
$ halrun
halcmd: loadusr -W zzlaser
halcmd: net ppp zzlaser.0.xxpos
halcmd: show
Loaded HAL Components:
ID Type Name PID State
3 User zzlaser 6262 ready
2 User halcmd6261 6261 ready
Component Pins:
Owner Type Dir Value Name
3 float IN 0 zzlaser.0.xxpos <== ppp
Pin Aliases:
Alias Original Name
Signals:
Type Value Name (linked to)
float 0 ppp
==> zzlaser.0.xxpos
sets ppp 2.000
From the above code, I can track the 2.000 value into the zzzfff file.
But if I run the same code from the EMC2 AXIS window, I got an error
message that zzlaser.0.xxpos pin does not exist as showed bellow.
Note: In order to get the zzlaser started when I start the EMC2 window,
the custom_postgui.hal file is filled with:
source zzlaser.hal
Error EMC2 window *************************************************
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
13 User zzlaser 6943 ready
12 User halcmd6942 6942 ready
11 User axisui 6928 ready
Component Pins:
8 float OUT 0 stepgen.2.position-fb ==> zpos-fb
8 bit OUT FALSE stepgen.2.step ==> zstep
13 float IN 0 zzlaser.0.xxpos
Debug file information:
/home/beldent/emc2/src/hal/components/zzlaser.hal:4: Pin 'zzlaser.0.zzpos' does not exist
6881
PID TTY STAT TIME COMMAND
6927
Stopping realtime threads
Unloading hal components
File zzlaser.hal:
loadusr -W zzlaser
show # to show the error message at EMC2 start-up
net Xpos motion.analog-out-00 => zzlaser.0.zzpos
File zzlaser.comp:
// zzlaser to read a laser distance
component zzlaser "zzlaser";
option userspace;
option extra_cleanup;
pin in float xxpos;
license "GPL";
#include <stdio.h>
#include <unistd.h>
FILE *fdp;
int zzcount = 0;
void user_mainloop(void) {
// open file
fdp = fopen("/home/beldent/emc2/src/hal/components/zzzfff", "w+");
if (fdp == NULL) {
// return -EBUSY;
exit(1);
else {
fprintf(fdp, "init: open OK\n");
fflush(fdp);
fprintf(fdp, "main loop: started\n");
fflush(fdp);
while(1) {
FOR_ALL_INSTS() {
if (xxpos == -1.000)
break;
zzcount++;
fprintf(fdp, "cnt=%d, Xpos=%f\n", zzcount, xxpos);
fflush(fdp);
sleep(2);
EXTRA_CLEANUP() {
fclose(fdp);
$ halrun
halcmd: show
Component Pins:
Pin Aliases:
Alias Original Name
Signals:
float 0 ppp
==> zzlaser.0.xxpos
sets ppp 2.000
source zzlaser.hal
RUN_IN_PLACE=no
EMC2_DIR=
Component Pins:
6881
6927
File zzlaser.hal:
loadusr -W zzlaser
File zzlaser.comp:
option userspace;
pin in float xxpos;
license "GPL";
#include <stdio.h>
#include <unistd.h>
FILE *fdp;
int zzcount = 0;
// open file
if (fdp == NULL) {
// return -EBUSY;
exit(1);
else {
fflush(fdp);
fflush(fdp);
while(1) {
FOR_ALL_INSTS() {
break;
zzcount++;
fflush(fdp);
sleep(2);
EXTRA_CLEANUP() {
fclose(fdp);
- Thank you received: 5018
11 Feb 2011 10:56 #7139
Replied by andypugh on topic Re:Need help about EMC2 error (HAL)
dubostjp wrote:
Is the problem just that you can't decide if the pin is called xxpos or zzpos?
pin in float xxpos;
Time to create page: 0.066 seconds
