User Interfaces
AXIS
Webcam lens position tolerances
turbospeedskater
Offline
Junior Member
Thank you received: 0
05 Apr 2011 11:40 #8549
by turbospeedskater
Hi all,
just a fast update from my side:
The sighting telescope did not work for a distance under 2meter...
But I found an old camcorder with a 75mm tele-lens in a 2nd hand store next door.
Adapter for the lens is ready and 1st test shows good result at 400mm distance.
Now I have to solve the problem how to mount a 500gr lens that is really large to the machine without movement and damages under heavy vibrating conditions...
I will give you an update as soon as I have made some tests.
User Interfaces
AXIS
Time to create page: 0.045 seconds
