Integrating Image-to-gcode to AXIS
12 Apr 2011 16:44 #8809 by dedetc
Integrating Image-to-gcode to AXIS was created by dedetc
Hello, just finished installing my EMC. Now, learning how to use it! I will use EMC to run a CNC Router, mostly for cutting and routing kitchen cabinet parts in MDF; I will be working with 2D files only for now. From what I have learned, I can use “Image-to-gcode” to generate a g-code file from a .png, .gif, or .jpg file. My questions are:
Where do I find my .ini file and [FILTER] section of my .ini file to integrate image-to-gcode with the AXIS interface? (sorry, no programming experience at all!)
Will Image-to-gcode work for converting 2D .dxf files?
Does the image-to-gcode generates a tool-path?
Thanks,
Carlos.
12 Apr 2011 17:57 #8813 by BigJohnT
Replied by BigJohnT on topic Re:Integrating Image-to-gcode to AXIS
Your config files are in your home directory under emc/configs/<your config name>.
I'm pretty sure image to g code will not read a dxf file however you might look a some of the other options...
Inkscape plugin that I forget the name
PyCam pycam.sourceforge.net/
There are some more on the EMC wiki page
12 Apr 2011 18:30 #8816 by andypugh
Replied by andypugh on topic Re:Integrating Image-to-gcode to AXIS
No. Try Gcodetools
www.linuxcnc.org/component/option,com_ku...0/lang,english/#1650
Yes, but not the sort you probably want. It converts an image to a Z-depth map, then creates a raster path to machine the surface. If you want kitchen cabinets with the faces of celebrities sculpted into them, then that is your tool. Otherwise, it isn't.
Time to create page: 0.107 seconds
